Old 06-21-2008, 12:49 PM   #15
vajeep's Avatar
1976 27' Overlander
Richmond , Virginia
Images: 49
Our 1976
Missy,
Our 1976 Overlander was leaking on the inside, I tried the hose and it was not blocked. What I did find when I removed the inside plastic cover was that the leak was comming from the clamp that attached the copper tube to the plastic drain tube. It took some moving around, but I was able to tighten the clamp and my inside drip stopped.
"Abe" & Melissa Lincoln
1976 Overlander "Spirit"
2005 Suburban w/q-steer
Hensley Hitch
vajeep is offline   Reply With Quote
Old 06-21-2008, 12:58 PM   #16
olddog299's Avatar
1990 25' Excella
Glenburn , Maine
While I like the chap who uses the weed trimmer and his drill as a possible solution, I didn't have one handy when I cleared my last plug. What I did have in the truck was a "fish tape" for conduit which is essentially really thick weed whacker line with a spring hook attached. I ran that up through from down below by hand and it did a great job.
wil
AIR 22828
TAC ME-3
Universal Address: 97XX5 QGG5Z
Longitude: -68.814136
Latitude: 44.894663
olddog299 is offline   Reply With Quote
Old 06-21-2008, 01:34 PM   #17
easyride's Avatar
1977 27' Overlander
1963 19' Globetrotter
Naples , Florida
I hope all the people saying compressed air are blowing down from top,if not they are just blowing the slime back into the pan for it to plug another day.Dave
easyride is offline   Reply With Quote
Old 06-21-2008, 05:12 PM   #18
Cyclist
henw's Avatar
2007 28' International CCD
Windermere , Florida
1/2 second of hose spray up the drain tube.
2007 28' Int CCD.
2011 F 250 Big Honking Diesel
DTV 5lnb on a tripod.
Wilson wired repeater with YAG.
Two big screens
15dB Backfire WiFi antenna and WaveMagnum
Centramatics.
Hawkshead Tire Monitors.
henw is offline   Reply With Quote
Old 06-24-2008, 05:02 PM   #19
1976 25' Tradewind
Fort White , Florida
A/C drain hose
My 1976 tradwind A/C drain hose is cracked inside the wall. With the a/c on water flows inside the the trailer . Dealer said they would have to take the walls apart to replace drain hose.
Question: Is it possible to run a drain hose outside the trailer, attached, to side to bottom? Anyone done this? I thought I saw this done some years ago.
Has anyone replaced their drain hose? and do you have to remove the wall panels inside?
Thanking all in advance,
nikon is offline   Reply With Quote
Old 06-24-2008, 08:16 PM   #20
richinny's Avatar
2011 34' Classic
i wonder if a smaller hose could be fished inside the old one? it would not handle as must water but it might help.
is anyone a heart surgeon? lol
Ricky
Old 06-24-2008, 11:21 PM   #21
lewster's Avatar
Naples, FL , Hood River, OR
It can be done!
Difficult, but possible.
First, you have to snake a pull wire thru the existing tube. Then, attach a smaller tube (they don't really have to be as big as they are!!!) and lube it up before pulling it thru.
It might take several tries, but it's worth a shot.
Old 06-25-2008, 01:32 AM   #22
72 tradewind's Avatar
1972 25' Tradewind
Willis , Texas
Images: 8
After you clear your tube you may want to take a small square of screen and zip-tie it around the end of the tube to keep out daubers etc.
72 tradewind is offline   Reply With Quote
Old 06-25-2008, 08:48 AM   #23
dscluchfc's Avatar
1984 31' Excella
Abernathy , Texas
why couldn't you snake a fish line through the present tube, attach a new tube to the fished line, and pull the old line out? Is it tied into the inside of the wall with a one way?
David
TAC # TX-18
AIR # 410
http://www.flickr.com/photos/dsphotoscapes
dscluchfc is offline   Reply With Quote
Old 06-26-2008, 01:45 AM   #24
1976 25' Tradewind
Smile A/C drain tube
One of the things I asked the service manager, why they could not attach another drain line to the existing one and pull it through? He said the drain line is stapled in various spots inside walls.
Did not know airstream would staple something to metal? I will have to check out my manual this weekend and see what options I may have.
Thank you.
Old 06-26-2008, 09:37 AM   #25
lewster's Avatar
Thank you.
The 'service manager' must think that Airstream uses wood 2 X 2's for framing like all of those SOB's I didn't know that you could 'staple' into aluminum!
Hopefully, he meant that the drain hose has 'strain relief' clamps or retainers at various points to hold it to the frame. Even so, they shou dnot be compressing the drain tube to the point that you couldn't slide a smaller tube inside.
It's worth a shot!
Old 06-26-2008, 12:39 PM   #26
I did put a new line in mine 3 years ago and it's still doing fine. It was quite easy in my Overlander although 4 inches of the tube can be seen next to the ceiling. I ran the new line on the curbside between the back of the oven and the wall and ended it between the tires. I did contemplate to end it into the sink's drain pipe but changed my mind so I could collect the water outside in a bottle if needed.
Live and LET live
FrenchBern is offline   Reply With Quote
Old 07-20-2008, 10:22 PM   #27
A girl and an Airstream
missysanford's Avatar
1993 29' Excella
dunnegan , Missouri
I'm afraid to ask why you collect it in a bottle????
missysanford is offline   Reply With Quote
Old 07-21-2008, 10:12 AM   #28
I guess it may be to top-up the battery, as it's a condensate. However, it probably picks up a load of impurities on it's way to the tube outlet.
Nick
Nick Crowhurst, Excella 25 1988, Dodge Ram 2500 Cummins Diesel. England in summer, USA in winter.
"The price of freedom is eternal maintenance."
nickcrowhurst is offline   Reply With Quote
low drain points Raptorrider2001 1999 Safari 19 11-13-2015 01:40 PM
Globetrotter 1963 - Kitchen Sink Drain Leak Under the Floor Uncle_Phil Plumbing - Systems & Fixtures 3 08-09-2002 06:59 PM
Armstrong drain lines davidz71 Furnaces, Heaters, Fireplaces & Air Conditioning 4 07-03-2002 09:01 AM
White water tank drain ramoore53 Fresh Water Systems 4 05-01-2002 10:08 AM
Easy clean dead bolt FrankR Doors & Locks 0 04-09-2002 12:32 AM
