Old 08-06-2017, 08:21 PM   #1
demijac
2014 27' FB Classic
Livingston , Texas
Send a message via Skype™ to demijac
Hot Water Issue When Boondocking
We get hot water just fine in our 2014 27FB Classic when we're plugged into shore power; we don't when we are boondocking. We've been on the road for several weeks and just noticed this problem for the first time a couple of days ago. We suspect there is a problem with the gas line to the hot water heater since it works just fine when we have shore power. We've had no problems with our other gas appliances when boondocking - just the hot water heater.
Our questions are:
1) what changed?
2) is there an easy DIY approach for diagnosis and fix, or is this best taken care
of at an RV service center?
3) if there is an easy DIY approach, what are the steps to diagnose and fix?
Thanks.
demijac is offline   Reply With Quote
Old 08-06-2017, 08:27 PM   #2
switz's Avatar
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction , Arizona
Images: 8
You have turned on the propane power switch versus the electric power switch for the water heater? Does the red light come on and stay on? That is a warning that it failed to ignite on propane. Check the burner area for mud dauber nests, they love propane fumes.
Old 08-06-2017, 08:28 PM   #3
Salem , Oregon
My understanding is that bugs will build a nest in burner and can cause the burner to not light. You can try compressed air to blow it out or coat hanger.
Dave
NoResults is offline   Reply With Quote
Hot Water Heater Works But No Hot Water Althea Water Heaters, Filters & Pumps 6 04-16-2016 10:45 AM
being frugal with hot water best ways to manage hot water cost lbdesign Full-Timing, Winter Living & Workamping 23 12-17-2015 10:14 AM
Hot water heater issue Bhkh226 General Appliance Topics 2 05-19-2015 12:25 PM
Hot hot hot aluminum! luvoldstuff General Repair Forum 23 06-24-2013 02:08 AM
AC just quit working and it's Hot Hot Hot!!! SaabLover Furnaces, Heaters, Fireplaces & Air Conditioning 9 07-27-2010 10:03 PM
