Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > Furnaces, Heaters, Fireplaces & Air Conditioning
Old 06-24-2002, 09:52 PM   #1
thenewkid64
Just a member
thenewkid64's Avatar
Profile:  Tampa Bay , Florida
Images: 21
HOT Topic for the summer-Air conditioners-Best/worst?
I know that there are many different makes of AC units on the market, but I have a question. Who makes one that is an aftermarket installable unit that cycles like your home AC? Meaning the compressor and fan turn off and on together.
How do you like the ones you have or have installed? Is there one that is easier for the DIY-er?
Where did you get the replacement? was it reasonable or downright cheap?
I LOVE my Armstrong unit but I know that one day it will break my heart and die on me, so I want to be as prepared as possible.
Brett G
WBCCI #5501 AIR # 49
"Stop worrying about the potholes in the road and celebrate the journey." -- Fitzhugh Mullan
Wise men talk because they have someting to say; fools, because they have to say something. -- Plato
In politics, absurdity is not a handicap— Napoleon
Old 06-25-2002, 09:32 AM   #2
jcanavera
jcanavera's Avatar
Profile:  2004 30' Classic Slideout
Fenton , Missouri
Images: 143
I had a Duo-Therm Brisk Air on my previous SOB trailer. It had a wall thermostat that shut the blower down once the compressor shut down. It did a lot better job on humidity control. Duo-Therm still makes these units today.
I know you can rewire existing units to work this way. There is a list serve posting somewhere from a person with instructions on how to do this. Personally, a little beyond my expertise but it can be done. I'll see if I can find this information.
Jack
Jack Canavera
STL Mo.
AIR #56
'04 Classic 30' S.O.
'03 GMC Savana 2500
'08 Vespa GTS 250
Old 06-25-2002, 09:53 AM   #3
jcanavera
jcanavera's Avatar
Fenton , Missouri
Images: 143
Air Conditioner Fan/Thermostat
I found the posting I was looking for but can't seem to copy and paste it. Here is the link to it. It discusses modifying a Coleman air conditioner so the unit works off a thermostat similar to a home system.
http://www.tompatterson.com/Airstrea.../msg00402.html
Jack
Jack Canavera
STL Mo.
AIR #56
'03 GMC Savana 2500
'08 Vespa GTS 250
Old 06-25-2002, 11:30 AM   #4
Action
Moderator dude
Action's Avatar
Profile:  1966 26' Overlander
Phoenix , Arizona
Images: 13
A/C
Brett,
Go to the Interior section and to A/C threads. I replied to a post by JAG on my experience in replacing my roof A/C unit.
I bought it at a RV salvage yard in Phoenix and I am very happy with the installation and the operation.
>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>Action
1966 Mercury Park Lane 4 DR Breezeway 410 4V, C-6, 2.80 - towing a - 1966 Overlander International Twin Bed
1996 Lincoln Mark VIII Diamond Anniversary 4.6L (275hp), 4R70W - 1990 Ford E 150 5.7L, AOD, 3.73 ____________________________________
Phoenix ~ Yeah it's hot however it's a dry heat!
Old 07-03-2002, 05:55 AM   #5
53flyingcloud
53flyingcloud's Avatar
Profile:  1984 29' Sovereign
1964 19' Globetrotter
1953 21' Flying Cloud
Amherst , New Hampshire
copy of posting
Arnie and Others,
Here is a post I copied from another list that talks
about setting up a wall thermostat to control fan and
compressor on a Coleman roof A/C. You may find it
helpful as a guide if you decide to tackle this
project.
>I have a Coleman 13.5K roof air (non-ducted). It has two knobs, fan speed
>and temperature.
>Is it feasable, and if so, has anyone successfully accomplished rigging a
>wall thermostat to control the AC, both fan and compressor?
Yes. Funny, you read my mind. This is the project I have underway
right now as I come in for a Gatorade break.
Warning: This technique will cause apoplectic fits in those whose
minds have rigidized to the point that thinking outside the box has
become impossible. I suggest that if you're of that sort, go to the
next message and don't have a cow or a stroke or something.
I want the furnace and AC to work in my RV the same way it does in
my house - separate fan and compressor/heating element control,
"fan/auto" control and with an electronic thermostat, automatic
switchover from heat to cooling and vice versa. This is pretty easy
to do, the only complication being there being 12 volts DC on the
control circuit instead of 24 volts AC. With one exception, this is
of no consequence. Most 24 volt AC relays will work just fine on 12
volt DC.
Here's what you need:
A thermostat designated for gas/electric service. This type of
thermostat will have the capability of bringing out the heat and
cooling fan contacts separately. (not used for my install but handy
if you want to control the heater fan. If you buy an electronic
thermostat, make sure it runs on internal batteries and does not use
sneak current from the 24vac supply.
3 15 amp HVAC relays with 24vac coils. These are commonly used as
fan relays on furnaces and ACs. My local dealer carries MARS brand
but any sort will do. You can use industrial relays with 12 vdc
coils but they're lots more expensive, don't work any better and
draw more coil power.
A suitable metal box to mount the relays in. A NEMA 1 4X4X3 pull
box will do.
Misc wiring stuff. Wire, wire nuts, tape, etc.
5 wire thermostat wire. Four wire telephone inside station wire can
be used if you use the chassis as ground return.
Mount the three relays in the box and mount the box near the breaker
panel. Connect an incoming pole of each of two of the relays in
parallel. This is connected to 120 VAC from the breaker panel. The
two relays will be the compressor and AC fan relays. The third
relay will switch 12 volts to the heater in place of the existing
thermostat.
Follow the instructions that come with the thermostat to wire it
up. Supply 12 volts from your fuse panel on the red wire. The
other standard color codes are:
Terminal label Color Function Note
Y ORAN COMP Compressor Relay
G GREEN FAN Fan Relay
W WHITE HEAT Heat relay
R RED HOT 12 volts from the
fuse panel
C YEL COMMON Chassis ground
Simply run each wire from the thermostat terminal to one coil
terminal of the appropriate relay and then ground the other coil
terminal of all the relays.
Inside the overhead air conditioner, remove the controls, making
note of how they were wired. Identify the neutral, the fan hot lead
and the compressor hot lead.
Here's where the wiring gets a bit hinky. We need 4 wires to the AC
- compressor hot, fan hot, neutral and ground. The problem is, most
rigs have a hunk of standard 12/2 with ground run to the AC and it
is almost impossible to replace. In my rig, the wire was run and
then the spaces were injected with foam insulation. The wire is
embedded in the foam. We can deal with this. We have 3 wires
running to the unit, a black, a white and a bare ground wire. We
simply redesignate the function of each wire. For my rig, I
designated the wires as follows:
black - compressor hot
white - fan hot
ground - neutral
chassis - ground
Obviously this is non-standard and will profoundly confuse the
average light bulb mechanic. Clear and attention-getting labeling is
a must. I labeled each wire using a Brother EZy Labeler and then
secured the label to each wire with clear heat shrink tubing. I
then printed a description of what is what on fluorescent yellow
stickers and stuck one inside the AC, on in the relay box and one on
the breaker panel.
Unhook the wire feeding the AC from the breaker panel. At the A/C,
connect the compressor hot lead to the black wire, connect the fan
hot lead to the white wire and connect the neutral to the bare
ground wire. Then bond the chassis of the AC to the RV chassis in
at least two places using green jumper wires and threaded holes and
screws and not sheet metal screws. The use of threaded screws in
tapped holes is required by the Code and is good practice. Sheet
metal screws in aluminum can loosen from differential expansion You
can buy the green screws at Lowe's, etc. You can also buy a hole
tap that looks like a screwdriver with a tap made onto the shaft
instead of a blade. For sheetmetal, you punch a hole using an awl
so that a good pucker sticks through the other side. This pucker
receives the threads.
At the breaker panel, remove the AC wire and run it to the relay
box. Connect the black wire to the compressor relay. Connect the
white wire to the fan relay. Connect the bare copper wire to a
neutral wire run from the breaker panel. Run a pair of wires from
the furnace thermostat input to the heat relay contacts. Check your
wiring, reassemble everything, power up and go.
You now have thermostatic control of both the furnace and AC. You
can have the fan run all the time as it does now by putting the fan
switch to the "ON" position. In "auto", the fan will start and stop
with the compressor, as the fan in your home AC does. Inside the
thermostat will be a "gas/electric" switch or jumper. If you leave
it set to "electric", then the overhead fan will run when the
furnace is on, when AC power is available, of course. This can be
desirable to help distribute the heat. Setting the switch to "gas"
will inhibit the AC fan when the furnace is running. If your
thermostat has built-in time delay to run the fan after the
compressor turns off and delaying the fan til the evaporator gets
cool, then these functions will work with your RV AC.
The thermostat I bought has the capability to automatically change
over from heat to cool and vice versa to maintain the temperature
setpoint. This is very desirable for dealing with those nights
where it gets very cool but then warms up in the AM before you
arise.
The only penalty is an additional, about 1/4amp 12 volt draw when
the heat is on. Of no consequence to me since I have plenty of
battery reserve.
John
AIR 807
53flyingcloud is offline   Reply With Quote
Armstrong RV Air conditioners pap Furnaces, Heaters, Fireplaces & Air Conditioning 45 11-13-2006 09:35 PM
summer air kenlmarc Furnaces, Heaters, Fireplaces & Air Conditioning 1 02-23-2003 10:47 AM
Heater and Air Conditioner Jeb Airstream Motorhome Forums 2 10-22-2002 08:45 AM
Air Conditioners JAG Furnaces, Heaters, Fireplaces & Air Conditioning 2 03-19-2002 02:25 PM
test
