Old 04-10-2015, 07:34 PM   #1
1990 29' Excella
baltimore , Maryland
high frequency squeal when furnace comes on
So I am thinking it is the furnace blower motor?
It only lasts for a few moments.
Is there a fix?
groundhogy is offline   Reply With Quote
Old 04-10-2015, 07:41 PM   #2
1986 31' Sovereign
Miami , Florida
If it only lasts a few moments, I doubt it is the motor bearings. Probably the fun is rubbing briefly.
Mike
new (usually dirty) Nissan Titan XD (hardly paid for)
Old (enhanced with "male pattern baldness") Sovereign
Young, lovely bride
Goofy dog, dismissive cat
Old 04-10-2015, 09:03 PM   #3
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
The fan motors are replaceable.
Old 04-10-2015, 11:18 PM   #4
J. Morgan's Avatar
1972 31' Sovereign
1975 31' Excella 500
Benton , Arkansas
Images: 11
My guess is that the fan motor bushings are dry.
If it was mine I would remove the fan motor, disassemble, and clean and lubricate the motor bushings.
By doing so you will likely extend the life of the motor for a long time.
1/2 Ton 4WD Truck, 72 Sovereign Hensley Arrow
Old 04-11-2015, 03:59 AM   #5
1977 31' Sovereign
1989 34' Excella
Johnsburg , Illinois
I had the same problem with my 77. Taking it apart and lubricating the fan motor got it to last another 3 years. When it started again I replaced the motor.
Old 04-11-2015, 12:33 PM   #6
1988 25' Excella
Santa Rosa , California
Happened to me too! Fan motor will get worse and worse until it's unbearable (think 2AM). Cut to the chase have the motor removed and rebuilt. Not necessary to replace the obsolete furnace.
gbryan1 is offline   Reply With Quote
Old 04-11-2015, 06:12 PM   #7
Sodbust's Avatar
1972 27' Overlander
Penokee , Kansas
Hello Groundhogy.. Welcome to the group..
Our 72 Overlander blower motor screamed when ever it turned on.. I pulled the unit out onto some old carpet so not to damage the floor and tore it all apart and cleaned everything up.. I used a very high grade turbine oil on the motor bearings and it runs like a new furnace for the past 2 years.
I love old tech for this reason.. Clean,, adjust,, and oil and it will be good for another 40 years.. No computer boards,, micro switches,, or other items outdated and made overseas
Sodbust
2012 Ram 1500 Tradesman Hemi, 4x4, 6 speed
20mpg empty, 14 mpg with 27' Overlander.
Today is the first day of the rest of your life!
Sodbust is offline   Reply With Quote
Old 04-11-2015, 08:05 PM   #8
J. Morgan's Avatar
1972 31' Sovereign
Benton , Arkansas
Images: 11
Sodbust
Bingo!!!
Old 04-12-2015, 10:44 AM   #9
1978 25' Tradewind
Superior , Montana
hello Groundhogy
I had the same problem on 1978 Safari took the furnace out and cleaned the complete furnace removed all the dust and rust and lubricated the fan motor bearings. I agree with J Morgan and sodbust to fix.
chuckg78 is offline   Reply With Quote
Roof-vent fan squeal Spot Roof Vents, Skylights & Fans 16 06-30-2011 03:56 PM
Furnace squeal Skater Furnaces, Heaters, Fireplaces & Air Conditioning 14 01-24-2011 09:18 AM
brake SQUEAL boondockdad Brakes & Brake Controllers 2 09-10-2009 11:14 AM
Brakes sometime squeal, wheel locks up RichHog Brakes & Brake Controllers 1 06-23-2009 11:42 PM
Ugly squeal chirocruzr General Motorhome Topics 8 06-22-2009 06:36 PM
