12-30-2009, 06:25 PM
banjobill
2000 30' Limited
battle ground,
High efficiency furnace(s)&multi speed blowers
Just spent a long weekend in 32 degree weather, which is cold for Eugene, Oregon. Used the furnace a lot. It is a 30k btu unit. and it went through a fair amount of LP Gas. So, I took a quick look around for a high eff rv furnace like the 90% unit in my house-there was a LOT of heat going out the vent of the furnace, which bummed me out. Did not find anything so I am questioning the forum-is there a 90-95% eff furnace out there for RV's? Also, my old unit cycled quite a bit-again, I think a constant low blower speed with the burner going on and off would provide a better heating operation inside the trailer. Any body mod their unit for constant low speed operation?
ol' bill
12-30-2009, 06:44 PM
Western
, Massachusetts
Catalytic
12-30-2009, 07:02 PM
Port Orchard
ol' bill
I am now on my third TT and the furnaces in all have behaved like that.
They blow a hurricane force wind and drive the temperature up before the thermostat has figured out what is going on. Then they shut off and do the whole thing over again a few minutes later. I have decided that I was going to look into slowing the fan down, but hadn't thought of letting it run constantly at a slow speed. There are obviously things to be considered, such as keeping the heat exchanger from overheating and burning up, and would running the fan continuously run the battery down too quickly when do on shore power? I have often wondered if RV manufacturers are putting too large furnaces in the RVs. In any case I am definitely with you. I would like to find some improvement.
Looking forward to reading some good ideas,
Ken
12-30-2009, 08:54 PM
Ottawa
, ON
This link may work better: PrecisionTemp.com: For Recreational Vehicles and Boats
It sounds very interesting, but regardless of what the unit actually costs, I sense that installing a complete heating system for a TT might wind up being quite a significant expense, not only in the hardware, but also the labour to install.
If anyone does investigate further, I would love to hear cost estimates.
“Courage is being scared to death, but saddling up anyway.” ...John Wayne...........................
12-30-2009, 09:07 PM
Naysayer
1968 24' Tradewind
Russellville
, earth
How about this http://www.precisiontemp.com/images/2009_Pricing.pdf
12-30-2009, 09:16 PM
2004 30' Classic Slideout
Fenton
, Missouri
If you want something over 90% eff you need to consider two issues. First you need to have a secondary heat exchanger which most likely means an increase in the furnace size. Once you get that in you then have to deal with a much lower temp exhaust which means some type of PVC venting system and condensate drainage.
Typical non eff furnaces send exhaust out at about 400 degrees. Eff furnaces vent in the 80 to low 90's. That means the moisture in the exhaust condenses and condensate which is acidic must be drained out. That works okay in a house where it drains into your basement sewer through a plastic hose. Try draining liquid out of a trailer in the freezing cold. The exhaust itself is routed through PVC due to the fact that the acidic moisture in the exhaust will destroy typical galvanized components.
I don't think in the near run you will find anything like a 90+ furnace in a trailer until you can address these issues.
Jack
Jack Canavera
STL Mo.
AIR #56 S/OS#15
12-30-2009, 09:31 PM
I would think it would be very difficult to put hydronics under the floor, but what about a thin hydronic "pad" running the length of the trailer, on top of the floor? I bet it could be made less than one inch thick. Then you could really take full advantage of a unit like the one in the link above.
I'm partial to wood heat myself, in fact I'm sitting by my woodstove in my livingroom while I type this. A friend of mine who used to be a fisherman told me to check out the small marine woodstoves before I buy a new furnace. He says they would burn for four to six hours on a small chunk of hardwood, and heat a small boat cabin well. I saw one in an Airstream on the forum here when I first started to lurk. I can't remember who it was now.
Rich the Viking
12-30-2009, 09:33 PM
Ottawa
, ON
Rodney,
Thanks for the splash of reality. I'll pass on that system.
Jack,
Very good points. And considering that even if one lives in the TT full time in colder climes, I can't imagine a payback happening any time soon.
All in all, I would be happy with just a two-speed fan on a new Suburban furnace. I think that a system like that, one that would keep air circulating all the time that I want it to, and only kick the speed up when the thermostat calls for heat would do a great job of taking the rough edges off the simple system an AS comes with.
In my opinion, this would make a more comfortable (read: even) temperature in the TT, and shouldn't cost much more than a standard system. Judicious adjustments of the airflow through the rather crude system that AS installs would help too, I feel.
I just don't know if a compatible two-speed motor and controller exist to achieve this.
Anyone?
12-30-2009, 09:40 PM
Naysayer
1968 24' Tradewind
Russellville
, earth
I think that a system like that, one that would keep air circulating all the time that I want it to.................
Anyone?
A cheap(er) approach is to run a 12v fan or the fan on the AC to keep the air moving.
12-31-2009, 06:06 AM
Vintage Kin
Fort Worth
There are installations of this; Uwe, I think on one of his retrofits. Granted, that would be one deee-luxe setup, but the trailer would gain by eliminating the space/housing for the water heater. This is the sort of appliance one expects, I suppose, the $150k level and above. One would have to be a dedicated cold weather camper.
12-31-2009, 06:40 AM
1969 31' Sovereign
Broken Arrow
, Oklahoma
You will have a problem with a 2 speed fan there is a safety device in RV heaters that shuts off the gas valve when the fan slows down called a sail switch.
Garry
12-31-2009, 07:18 AM
Wise Elder
2010 30' Classic
South of the river
Jack is absolutely right. To get up above 85% you have to have a condensing furnace which adds complexity, weight, and size.
A smaller furnace might help. Units with fewer BTUs often have smaller fans. As a rule of thumb the furnace should run at least half the time on a fairly cold day, or it's oversized.
At least some of the recent Atwood furnaces claim efficiencies in the high 70%s. Not bad, really, considering that 55-60% was common for household furnaces 25 years ago.
12-31-2009, 08:07 AM
Fenton
, Missouri
One of the problems is the real lack of insulation. When it really gets cold, you know within minutes when that blower shuts down, that the cold is creeping back in. The other issue is thermostat placement. In my last two Airstreams, the thermostat was placed on the wall that houses the refrigerator. Any use of an exhaust fan, bathroom or stove causes air movement in that triggers the thermostat. In the summer the hot air in the compartment prematurely triggers the A/C. Like wise in the winter it triggers the cold air. I've put some silicone caulk into the hole that the wires pass through for the thermostat but it's not the end all to this problem.
In reality, I'd like the ability to have a two stage burner on the furnace with it's resultant two speed motor. My current home furnace has this feature and the way it was explained to me was that a typical single stage burner and fan have one goal in mind....to get the thermostat up to set point. In a two stage furnace it takes more time, but it allows the warm air to permeate the house better, which eliminates hot spots and makes the temperatures more even. If you think about it, most homes have their thermostat in a central core area. With a single stage furnace the areas outside the central core will hit set point sooner than the thermostat. If the heat is more gradual, both in temp and blower speed, you don't get the extremes in the outer areas prior to the thermostat seeing the set point.
In the trailer being able to select a slower blower and burner setting would keep things running longer, and would minimize the wild swings in temperature. As a bonus you wouldn't have those moments when the cold pours off the walls while you wait for the cold to hit that thermostat.
Jack
Jack Canavera
STL Mo.
AIR #56 S/OS#15
12-31-2009, 08:19 AM
Ottawa
, ON
Read my post again, Garry; I only want heat when the theromostat calls for it. The fan on (at a lower speed, and therefore quieter) all the time is to keep the cabin at a more equal temp, but when heat is expected the fan goes to the normal (high) speed.
Two-speed fans are quite common in home forced air systems, but I haven't heard of them in TT installs, so this is a dream at this point.
Rodney,
Cheaper yes, but in my dream, I am not adding another system, I am modifying the existing one. After all, the whole point is just to keep air moving so that the normal tendency of large variations in cabin temp that an on/off fan situation makes are somewhat smoothed out.
The ductwork in the TT is used to keep all areas at one temp, instead of having one part colder than another, which is what our trailer is like now.
Plus, the noise from the AC fan system is like a diesel truck passing through the room. We only use that when it's really hot or humid.
12-31-2009, 08:20 AM
2007 25' Safari FB SE
Bozeman
, Montana
Last March I installed an Atwood Excalibur XT two stage furnace. It has cut down the noise and stays on low speed once warmed up. I have used it in 20 deg. nights. I went with a lower BTU (16000 - 22000) even though my trailer had a 25,000 BTU furnace.
No problems with warming up. Seems the low speed is more efficient on propane.
Doesn't wake me up in the night like the old one.
HOWEVER,
I have been working with Atwood on an annoying hum. So far, I am on the second engineer, and they have replaced most components. Next is an Atwood paid new
furnace install, cause they don't seem to be able to find the hum in my unit.
So in January I will report on its progress.
Hank
WBCCI 1489 AIR 20708
2015 Chevy 3/4 ton 4 x 4 gas; 2007 Safari FB SE
"Its better to light just one candle than to curse the darkness,
Unless you're blinded by the light..."
12-31-2009, 08:28 AM
Ottawa
, ON
Wel duh, it DOES exist! And at pricing that isn't significantly more than the regular single-stage furnace. Here is a link to the one that Hank is talking about above.
Thanks, Hank! Looking forward to your January report.
And thanks too, to Jack for his much better explanation (in post #14 in this thread) of the problem and potential benefits of a two-stage system. AND, another part of the problem, the lack of decent insulation.
Aage
12-31-2009, 09:34 AM
banjobill
2000 30' Limited
battle ground,
allrighty now!
yessiree, you guys rock! during my cold stay, the furnace came on and off as stated, and I think that the startup on the motor would actually cause more battery drain than a more constant, low speed operation. I do have an olympian catalytic out in the front of the coach-keeps the front toasty, with no blower, but, I am not sure it would heat the back much? dunno haven't tried that, yet. Obviously, my coach is allllllllmost 25 years young, and from the sound of the furnace blower when it first starts up, it at least needs lubing, or new bearings. So, I like to fix stuff once if possible, and will look at the new furnance XT models very hard. If I gotta yard the existing one out to lube/bearing it, I might just as well spend a few more bucks...afterall, it is the American Way!
bill
12-31-2009, 09:50 AM
banjobill
2000 30' Limited
battle ground,
eight steps to furnace removal
Well, the service manual has a total of eight steps to remove the furnace...reads real easy-there are two steps, that my experience causes a red flag to shoot up, though. So I will see how easy it is...leaving the dang thang together allows me to take spontaneous trips, tho, so I will "sneak" up on it...
12-31-2009, 10:17 AM
Bozeman
, Montana
I also have had the problem of thermostat location. It was in the bedroom, and since I always got up hours earlier than the wife, I was generally too warm in my section with the divider closed. I placed the new thermostat with my XT in the front on the side of the refer. I put four 1 inch rubber standoffs to keep the refer wall from influencing the Tstat. It seems to work well, as I have a thermometer near it, and the air temp is within a couple of degrees of that reading on the Tstat. Also, the bedroom stays cool while my living space is just right.
Hank
