Old 02-04-2015, 03:41 PM   #1
1965 26' Overlander
Greenville , Texas
Help with my furnace
Hello, my furnace pilot lites but the unit will not turn on any one know how to fix the problem
gomez1965 is offline   Reply With Quote
Old 02-04-2015, 04:37 PM   #2
ottawa (greely) , Ontario
It would help if you gave us more info on the brand of furnace ,model,and year,
If it's a type of furnace were you light the pilot ,some models require you to hold the pilot valve down for a minute ,this is part of the safety system as there is a sensor that shuts off the pilot valve if the pilot blows out once it was lite and you realeased the pilot button ,are you holding this valve in the pilot position for a minute or so, there could be a problem with this system ,or air in your propane line if you haven't had the furnace running in awhile, could have a bad gas valve or dirty orifice jet ,but we need more info !
Don
2012 silverado ext cab 4x4 ,5.3 L , 6 speed trans,3:42 final drive,tow package standard box 6 1/2 foot . 2014 honda forza 300 scooter, #2 2015 honda crf 250 L (Dual sport)
scamp is offline   Reply With Quote
Old 02-05-2015, 08:37 AM   #3
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
If the pilot stays lit once you let up on the safety over ride button. You have gas.
Is the thermostat calling for heat?
Is the blower running?
It could be the sail switch, the over temp thermostat, the gas valve, the purge timer or low gas pressure. For example.
More details are needed.
Old 02-05-2015, 08:46 AM   #4
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
First, If the furnace is original would you live in a home with a 50 year old furnace?
Second it sounds like the problem may be your thermostat, not the furnace. Disconnect and cross the wires and see if the furnace starts.
Third, has the furnace recently worked for you?
Furnace fumes from new furnace rosser7 LP Gas, Piping, Tanks & Regulators 15 06-01-2013 10:17 AM
Surburban Furnace Ills - HELP Cat Furnaces, Heaters, Fireplaces & Air Conditioning 22 07-07-2005 08:22 AM
Atwood furnace issue--Help?! Silvertwinkie Furnaces, Heaters, Fireplaces & Air Conditioning 9 03-01-2005 09:31 AM
furnace help me frederic.c01 Furnaces, Heaters, Fireplaces & Air Conditioning 4 09-28-2004 11:34 AM
HELP!! Furnace frustration! Forrest Furnaces, Heaters, Fireplaces & Air Conditioning 18 01-26-2003 08:41 AM
