Old 08-15-2006, 08:48 PM   #1
Darrell Root's Avatar
2004 28' International CCD
Camarillo , California
Help with dripping A/C in trailer
Help please the a/c drain line seems to be plugged, my wife is in Louisiana and I am here in Ca. She had some one try and fix but it seems he tried to clear from top and bottom and now its not driping outside at all. When she tried to stick a coax cord from bottom met resistence at about 4' up. Has any one tried a small diameter auger? Any ideas welcomed. Darrell
Darrell Root is offline   Reply With Quote
Old 08-15-2006, 09:49 PM   #2
uwe
418
uwe's Avatar
2007 25' Safari FB SE
1958 22' Flying Cloud
1974 29' Ambassador
Yucca Valley , California
Images: 41
Can you get compressed air to it somehow? Blowing into it will either clear it or at least make it easy to locate the problem by following the hissing noise.
Uwe
www.area63productions.com
Old 08-15-2006, 10:05 PM   #3
Link
Thanks , that is one consideration my wife will have to buy a compressor. When the guy she had help her actually blew into the hose more water came in the trailer,but in trying to clear the hose it got blocked up completely. The problem is no one there to tow the trailer and the temps have been 100 /95 humidity Darrell
Old 08-15-2006, 10:08 PM   #4
Calvin's Avatar
1966 26' Overlander
Waskom , Texas
Hi Darrell,
A sink cleaning cable would work better than a coax. It is a small flat steel blade type used to clean smaller sink lines. They are about 5 to 10 feet long and available at builder supplies and plumbing supplies for around $5 to $10. If you do not have access to compressed air, this might work.
Calvin
Calvin is offline   Reply With Quote
Old 08-15-2006, 10:49 PM   #5
Link
Thanks Calvin thats what I was thinking they have one at Harbor Freight and by luck theres one in Alexandria and my wife is going there tomorrow. I just can't figure out what is stuck in there.
LT versus ST tires on a trailer 76Argosy Tires 18 08-29-2014 04:03 PM
'78 airstream trailer lbf78SvgnInt31 General Interior Topics 4 10-21-2006 12:09 PM
1971 Armstrog A/C uwe Furnaces, Heaters, Fireplaces & Air Conditioning 2 08-06-2002 05:08 PM
Check your aging A/C shroud Jim Clark Furnaces, Heaters, Fireplaces & Air Conditioning 2 07-25-2002 10:30 PM
Missing piece for Armstrong A/C? 74Tradewind Furnaces, Heaters, Fireplaces & Air Conditioning 1 07-10-2002 04:16 PM
