We have tried the A/C a couple of times before and it had been working. Now that we are getting close to actually using our AS we checked it again and are not getting any cold air.
When we turned it on at first we got a loud rumbling which subsided quickly, I assume this was the compressor. The fan came on fine too. I am hoping all we need is refrigerant. However, we don't know what the settings are on the thermostat. In the manual it says to set to "cool" ( probable a good idea) but we don't have any marked setting for that.
We have three distinct settings that the control "clicks" to. The first is marked "sys" ---system?? And the other two have no id marks at all. Can someone enlighten me as to what they are and which would be "cool"?
Wannaroam,
Stupid question; are you plugged into a 30 amp cirquit??? Don't try to run the AC unit on one of those 15 to 30 amp adaptors. You will ruin the AC unit.
Carl, Elaine & Finn The Beagle
2006 30' Classic W Slide & Limited Package Katarina
2006 GMC 2500 HD 6.6 Turbo Diesel Crew Cab 8' Bed
TAC PA-3
S/OS#042
AIR #14487
NQ3U (was KB3UOM)
Make sure that the compressor is really running. Sometimes it takes a few minutes for the compressor to start, depending on the model. If the compressor is running and you don't get cold air from the unit uou may be low on gas, a clogged capillary tube or a faulty compressor. Good luck.......
