Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > Furnaces, Heaters, Fireplaces & Air Conditioning
Old 04-18-2013, 05:52 PM   #1
beaumont , Texas
help with A/C '69 safari with no A C
I am trying to install a Coleman a/c unit on my 69 Safari. Problem is that it came from the factory with no A C. There has been some debate on the forum whether or not the wiring and drain line are in the ceiling. I have looked through the threads, and seen that some have been lucky and found their wiring. The shop that is going to install says their sources say no wiring is there, and there are only 5 main ribs in this 23 ft. safari. If Andy is out there anywhere, please help .. dont want to cut the hole in the wrong place, and would like to be more sure of the possible lack of wiring. thanks.. Richard
Dixie722 is offline   Reply With Quote
Old 04-19-2013, 02:37 PM   #2
Moderator Emeritus
overlander64's Avatar
1964 26' Overlander
1978 Argosy Minuet 6.0 Metre
Anna , Illinois
Images: 194
Greetings Richard!
Your Safari should have the factory air conditioner prep package even if it didn't come from the factory with air conditioning. Two things that you can check for indicators are for the presence of the condesate drain (look at the bellypan near the streetside axle . . . you can usually find the drain tube sticking down below the bellypan in that area), and check your circuit breaker box for the existence of an unused circuit breaker (present for the future installation of an air conditioner). You can also contact Airstream Customer Support with the information contained in this link.
My 1978 Minuet had never had an air conditioner when I purchased it in 2003, but utilizing the measurment instructions provided by Airstream, my installer was able to immediately locate both the power cable and condesate drain tube without problem.
Good luck with your project!
Kevin
Kevin D. Allen
WBCCI (Lifetime Member)/VAC #7864
AIR #827
1964 Overlander International
1968 Safari 22' :: 1968 Airstream Safari Darrengj Airstream Registry Discussions 1 02-09-2020 07:28 AM
Safari :: 1996 Airstream Safari Land Yacht tlw12 Airstream Registry Discussions 0 12-18-2011 08:47 AM
A/C leak only with sideways rain Bowmans Leaks - Weatherstrips, Gaskets, Caulks & Sealants 3 10-07-2011 10:47 AM
No Power To A/C (power at breaker) vhariable Electrical - Systems, Generators, Batteries & Solar 3 06-28-2011 05:54 PM
