Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > Furnaces, Heaters, Fireplaces & Air Conditioning
Old 08-14-2006, 09:11 AM   #1
kbmckay
Profile:  1969 27' Overlander
Bossier City , Louisiana
Help with A/C
I have an original Armstrong A/C ('69) that works great--until the thermostat temp. is reached. At that point, the unit makes a lot of LOUD clicking noises and a few rattles as it tries to turn the compressor off. It will eventually turn off (compressor), but repeats the problem when it once again reaches desired temp. If I turn it off manually, no problem. Any ideas?
Kent
kbmckay is offline   Reply With Quote
Old 08-15-2006, 04:39 AM   #2
RVnDixie
RVnDixie's Avatar
Profile:  1975 28' Argosy 28
Homewood , Alabama
Thermostat is confused!
I believe that the thermostat is trying to decide whether or not to turn off the compressor. Try replacing the thermostat.
Joseph Tolliver aka "T"
Amy Tolliver
1975 Argosy 28D (work in progress!)
RVnDixie is offline   Reply With Quote
Old 08-23-2006, 09:39 PM   #3
kbmckay
RVnDixie, you are correct. I replaced the thermostat with a new digital one and it works great. Thanks.
Kent
Old 08-24-2006, 12:20 AM   #4
RVnDixie
RVnDixie's Avatar
Homewood , Alabama
Kent,
You are most welcome! I'm glad my suggestion helped! That should fix you up for a good long while.
"T"
Amy Tolliver
A/C replacement? VWMARTINEZ Furnaces, Heaters, Fireplaces & Air Conditioning 6 03-09-2007 03:14 AM
A/C removal Rob Furnaces, Heaters, Fireplaces & Air Conditioning 14 04-22-2003 07:53 PM
1971 Armstrog A/C uwe Furnaces, Heaters, Fireplaces & Air Conditioning 2 08-06-2002 06:08 PM
Check your aging A/C shroud Jim Clark Furnaces, Heaters, Fireplaces & Air Conditioning 2 07-25-2002 11:30 PM
Mediocre A/C Chuck Furnaces, Heaters, Fireplaces & Air Conditioning 4 07-07-2002 08:52 PM
test
