Old 06-18-2014, 06:49 PM   #1
Havelock , North Carolina
Angry HELP with a '74 Sovereign Airstream AC
Need help on how to remove the AC on a 74 Airstream Sovereign. AC had quit and we are in 100 degree F weather....have already got capacitor but don't know how to remove so we can fix it.
holmant is offline   Reply With Quote
Old 06-18-2014, 06:59 PM   #2
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
The capacitor is inside the shroud. No removal of the air conditioner should be needed.
Old 06-18-2014, 07:11 PM   #3
How do you remove the shroud?
Old 06-18-2014, 07:16 PM   #4
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 40
Bolts on top IIRC. Haven't been on top of my AS in a while.
Aaron
WBCCI #XXXX AIR #2495
Old 06-18-2014, 07:24 PM   #5
OK. THANK YOU. I am transferring this info to him as he is in Enfield, NC. What is the IIRC?
Old 06-18-2014, 07:30 PM   #6
J. Morgan's Avatar
1972 31' Sovereign
1975 31' Excella 500
Benton , Arkansas
Images: 11
If it is like mine the shroud will be bolted through the side if the shroud on either side.
Again, if it is like mine, there will be some components under the inside shroud also.
FWIW, the only time mine didn't work there was a single screw that had fallen out of the relay.
This relay was in a metal box under the inside cover.
Old 06-18-2014, 07:42 PM   #7
Thank you!! I have transferred your response to him.
Old 06-18-2014, 07:43 PM   #8
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Images: 40
IIRC=If I Recall Correctly
We are assuming he has the original Armstrong Bay Breeze, I know much newer models have large screws on the top, and the shrouds are typically one piece. The Armstrong unit has a two piece shroud. Haven't had mine off in over 6 years so I don't remember exactly how it comes off.
Aaron
Old 06-18-2014, 08:53 PM   #9
He has a 31 ft Airstream Sovereign. Thank you.
Old 06-18-2014, 08:54 PM   #10
His air conditioner manufacturer is out of business.....they quit making his AC yeaars ago. Parts are hard to find for it.
Old 06-18-2014, 09:29 PM   #11
Ottawa , ON
Hold the phone there pardner..!
Don't count them out: it seems that all the core parts are still available in the marketplace. Those are very rugged machines.
Take a few minutes and read Jason Pratt's thread where he completely rebuilt his, and even upped the output power AND added the 'heat pump' function to it!
http://www.airforums.com/forums/f427...tml#post981050
sovereign
1976 Airstream International Sovereign :: 1976 Airstream International Sovereign AirVintage Airstream Registry Discussions 0 04-16-2012 10:26 AM
1973 Silver Sovereign 31! AIRSTREAM. LOW RESERVE S1973 Silver Sovereign 31! AIRSTREAM eBay Watch Airstreams on eBay 0 09-22-2011 11:20 AM
Help! Need help with parts - '69 Sovereign kimcup General Repair Forum 6 06-08-2009 09:54 PM
Help Help Help!!! rebel beck 1974 - 1979 Sovereign 9 01-07-2006 03:00 PM
