Old 09-07-2012, 01:08 PM   #1
Cowgirl @ heart
FAIRBURN , Georgia
HELP - Thermostat Wiring Assistance Needed!
I'm in dire dire need of help. Just bought '79 Sovereign and chg a/c thermostat from prong to non-diigital Honeywell. 1st attempt was to connect wires as orig, 2nd attempt to. Connect as suggested by another person. I hv a brown, red and green wire, pls help.
A/c worked beautifully upon inspection and i knew I needed to chg thermometer, but I'm missing a link. Thanks for any suggestions.
LuckyLil is offline   Reply With Quote
Old 09-07-2012, 02:42 PM   #2
Minno's Avatar
1972 31' Sovereign
Lexington , Minnesota
Did the a/c work with the original thermostat? If yes, re-install it to make sure the a/c still works.
Then, if you can post some pictures of the original thermostat installed, showing the wire connections, and a picture of your new thermostat showing where the wires connect, I think someone here will better be able to help you.
Old 09-07-2012, 09:37 PM   #3
Cowgirl @ heart
FAIRBURN , Georgia
Thank u so much......this has been so frustrating due to incredible heat and humidity. It will be a couple of days, but pls watch for pic. Thank you for your help.
