Old 09-24-2017, 12:01 PM   #1
2014 27' FB International
Sanford , North Carolina
HELP, no heat
Any help greatly appreciated. It's 43° in Spearfish South Dakota and the heat suddenly stopped working. We have a Dometic Thermostat, Dometic A/C heat pump and a furnace (I think Atwood) in our 2014 27 International.
Initially there was an E1 Error code. Then the furnace turned off. The stove continues to function and the 110 V and 12 V systems seem otherwise intact. We are on shore power and have been at the site for five days.
Read the manual, searched online and reviewed Forums. Found a similar thread [http://www.airforums.com/forums/f37/...a-105148.html]. Reset the thermostat. Held down the program key until program disappeared. Now zone one is blinking with a non-blinking "4" off to the right.
Using the mode switch the unit cycles through off, cool, and fan but not furnace or heat pump. This isn't mentioned nor is it anywhere online I can find. I've also thrown the circuit breaker marked A/C off and then on again several times.
Any help is greatly appreciated. . . Brrrrr.
Sharon_Jon is offline   Reply With Quote
Old 09-24-2017, 01:45 PM   #2
Foiled Again's Avatar
2012 25' FB Eddie Bauer
Virginia Beach , Virginia
To reset inside breakers you have to push them down all the way before pulling them back up. Do your wall outlets work on AC power? If unsure reset the breaker on the shore power post.
At 42° your heat pump should work, colder it should switch to propane furnace mode... However a furnace sucks propane so you might be low or out. Try lighting a stove burner. And open the valve on the second tank if it's closed.
You don't say whether you have solar or a big battery bank and oversize inverter . Factory OEM lets you use very limited battery capacity thru the inverter.. to keep ypu from ruining your batteries, but even the bigger boondocking systems have limits.
If you set the thermostat to AUTO and 70 degrees the heat pump should start at 67 or so IF your shore power is good. And of course you could run to Walmart and buy a space heater for a short term fix.
The thermostat WAS designed by Satan. But the E1 normally happens when shore power is cut, a circuit breaker pops and/or the backup furnace can't fire.
Paula
Old 09-24-2017, 02:00 PM   #3
No Heat
Thanks so much for your prompt reply.
I have reset the breakers with the correct procedure you describe. The wall outlets seem to work fine. Our space heater is indeed going.
The stove works fine, good flame from the burners. Both tank valves are already open.
We have standard Interstate batteries and a 50 amp Airstream solar panel and inverter. Our system has worked for more than a year of camping days.
Cannot set the thermostat to auto because it only cycles thru off, fan and air conditioner over and over.
Thanks for your thoughts and ideas, we will try turning off shore power at the pedestal.
Old 09-24-2017, 02:12 PM   #4
More
Turned off the power at the pedestal and found that the batteries are very low. But should be a factor when we are on shore power? We've been concerned about that problem and have an appointment with Lewster in Naples but not until February.
Old 09-24-2017, 02:20 PM   #5
GLCMRANGER - Sue
2016 25' International
Littlestown , Pennsylvania
This happened to me. Your batteries are "Toast"! You need a minimum amount of 12v battery power for the furnace fan to turn on. The exact same error code and symptoms happened to me. I replaced the batteries --- Furnace started working again. It doesn't matter if you're on shore power or have solar. IF your batteries won't hold a charge, it's a mute point!
glcmranger is offline   Reply With Quote
Old 09-24-2017, 02:44 PM   #6
Al and Missy's Avatar
2002 30' Classic S/O
Melbourne Beach , Florida
Have you checked inside the furnace compartment for a fuse or circuit breaker? Go outside, open the door to the furnace and look around for a fuse, breaker or a loose wire. For some reason the control board in the AC unit doesn't know the furnace is there. There could be several reasons: low voltage, bad connection between the thermostat and control board in the AC unit, corroded furnace DIP switch on the control board, or a problem in the furnace itself.
Do you have a voltmeter? If the batteries are at 12.6 volts, the furnace should work. Unless you have a shorted cell, they should read good voltage while the converter is on. If your voltage is OK, you may have a bad connection between the thermostat and the control board in the AC, or the DIP switches that set the configuration may be corroded. Check the cable (like a modular phone cable) between your thermostat and the AC unit. Unplug each end, clean the wire contacts with an eraser, reconnect and reset. If that doesn't work, work the switch that tells the thermostat that there is a furnace present back and forth to clean the contacts, reset and try again.
If you read low voltage, say 10 volts or lower then the batteries have a shorted cell and are pulling the converter voltage down. Then:
1. Disconnect from shore power
2. Disconnect the negative terminals of both batteries and tape them up in plastic bags to prevent shorting to the frame or skin of the trailer.
3. Reconnect shore power
4. Reset thermostat and try again.
NOTE: This will disable your breakaway braking. Reconnect the negative cables or replace the batteries before moving the trailer.
This will remove the load the batteries are placing on the converter and system voltage should go back up to 12 or 13 volts. IF not, your converter is toast. Lights and other things might still work. I don't know the voltage tolerance of the control board and thermostat.
Al
Al, K5TAN and Missy, N4RGO
2002 Classic 30 Slideout
S/OS #004
Old 09-24-2017, 04:35 PM   #7
Conclusion, hopefully
Al, thanks so much you're amazingly detailed step-by-step instruction. It worked! We first went outside and checked for loose wires. There were none. There was an on off switch which we switch off and on a bunch of times. Came inside and there was no change.
We next checked the batteries with a voltmeter. With the converter running readings across both was close to 14. We then came inside and remove the thermostat. Tried to clean by blowing and pushing off and on the phone jack. When we replaced the thermostat it showed only done four, hopefully as shown in the attached photo. We only have one zone. The thermostat still did not see the furnace nor heat pump.
We then reset the thermostat and it recognizes zone one and works. Perhaps one of the contacts in the switch outside or on the telephone-like connector was not clean. . At any rate, things are working now and hopefully will remain so. Your help is greatly appreciated.
Old 09-24-2017, 08:59 PM   #8
carbondale , Colorado
eVERYONE IS SO KNOWLEDGABLE. Thanking you in advance for your help. WE just-meaning today- picked up a 2017 26 FC from a friend who is already going larger. He has been on shore power for the summer and is not that familiar with the systems. Anyway, it is in our driveway and NOT yet hooked up to the house power. It's getting cold out, around 50 and since I've been "playing" with it all day I decided to try the heat on batt/propane to see how it does. Batt disconnect off. Set thermostat first to HP-nothing. Than changed it to heat and E7 came up. That in the booklet says no 120v- which I knew. But still nothing went on. Propane tanks open. What am I doing wrong? BTW, is it just me or is the AS manuel a pretty non-informatve booklet for such an expensive piece of equipment. Thanks so much.
capt_ron777 is offline   Reply With Quote
Old 09-24-2017, 09:27 PM   #9
From the CCC2 Manual -
Press the MODE button to cycle
through the mode options. A mode is
an operation that can be performed
by the unit and is controlled by
the Dometic CCC thermostat. The
available modes are: OFF, COOL,
HP (HEAT PUMP), HS (Heat Strip),
FAN, FURN (Furnace), and AUTO.
The available modes are determined
by your system options.
You need to put the thermostat in FURN mode. HS (heat) is for electric heat strips in the AC unit which are an alternative to heat pump and require AC power to operate. Do you see a FURN mode?
Al
S/OS #004
Old 09-24-2017, 10:16 PM   #10
Problem again
We went we went out and came back to find E1 and the system not working again. Still only cycles through off, fan, and cool wrhen the mode button is pushed. . I've tried the same things as last time but can't now get zone one in operation. After the word zone in the picture the "1" is flashing and the "4" is on constantly. Any other ideas or appreciated.
Old 09-25-2017, 06:15 AM   #11
GLCMRANGER - Sue
As I mentioned before: REPLACE YOUR BATTERIES! Turn disconnect switch to STORE -- Wait an hour. Take voltmeter reading at the batteries. Any reading below 11.7 means batteries compromised and FURNACE WILL NOT TURN ON!
Old 09-25-2017, 06:50 AM   #12
Lily&Me's Avatar
Normal , Illinois
One of the things it might be good to put on your must-have list, for just such furnace kaput occasions, is one of the small, highly efficient space heaters that many of us carry.
It won't fix the furnace issues, but they provide an amazing amount of heat and even visual comfort if you get one of those that looks like a tiny fireplace.
Our thermostat went out in the second year or so of ownership, and the space heater saved us from freezing solid when we were stranded during an ice storm in Missouri.
Just a thought for future events...
Maggie
Old 09-25-2017, 10:53 AM   #13
To Al, I think your response was to me. I am sorry, I meant to say furnace. That is what I put the mode into and it did nothing but said E7. One other question if you would, I'd like to get a fuel gauge for the two propane tanks. Any recomendations and where does it get placed. Is the present one- which on mine right now is showing all green with an arrow I guess pointing to operable tank- at all reliable? Thanks again
Old 09-25-2017, 11:48 AM   #14
sorry , just went back in to as and played with the thermostat again. Put it in different program- 1- and went to furnace and set temp to 70- inside temp is 39- and nothing goes on. Also this time didn't say E7, just showed set temp for 70 ,but no response. Am I not turning something else on?
Using the heat pump/heat strip instead of furnace. crazylev On The Road... 38 10-28-2016 08:58 PM
Heat Pump - Replace with an AC or Heat Pump? A W Warn General Repair Forum 32 10-12-2015 03:18 PM
To heat pump, or not to heat pump, that is the ?? MacDad Furnaces, Heaters, Fireplaces & Air Conditioning 16 09-06-2014 10:58 PM
Heat pump or heat strips? coolwhip40 Furnaces, Heaters, Fireplaces & Air Conditioning 14 08-30-2011 02:14 PM
New AC, Heat Pump or Heat strip? firedog 1990 - 1993 Excella 3 01-22-2010 05:23 PM
