We replaced our furnace in our '70 Safari a year ago. Has worked great with no problems. Over this past winter our existing battery went kaput, and we bought a new one today. As soon as we connected the new battery the fan on our furnace kicked on and stayed on. (no gas on to feed the furnace- just the fan), Even though the thermostat was off....
Someone replaced the original, but it is just a switch anyway. Try removing one of the wires and see if the fan stops. One wire is 12 volts and the other returns the 12 volts to the furnace when the contacts are made.
Richard Wally Byam Airstream Club 7513
We replaced the original furnace and thermostat a year ago. But all has worked perfectly up until today, when we replaced the battery with a new one... I'll undo the connections and see what happens...
Just a thought...unhook one or both of the wires going FROM the thermostat TO the furnace...that will eliminate the thermostat as the problem...THEN reconnect it...and unhook the wires AT the furnace coming FROM the thermostat...that will eliminate that and the wiring as the problem...
__________________ Jay (KB8VMO) WBCCI #10917 AIR #32349 TAC #WI-2
