Old 08-08-2010, 05:39 PM   #1
MyHappyPill's Avatar
1977 Argosy Minuet 6.0 Metre
St. John , Indiana
Help I'm roasting
So I just had my Dad install my new penguin duo therm air conditioner. When testing it out at home, it ran, but blew the breaker. We thought it would work fine at the campground with more power. WE WERE WRONG! I am now camping/cooking. My air runs for up to about 5 minutes, but then shuts off. The breakers are not flipping. The air will restart after 5 minutes or so, without needing to touch the breakers. Any ideas??? I'm desperate (and hot!)
Jill
MyHappyPill is offline   Reply With Quote
Old 08-08-2010, 05:48 PM   #2
Jim Rogers
jimrogers's Avatar
Jonesboro , Arkansas
try putting in a 30 amp breaker
jimrogers is offline   Reply With Quote
Old 08-08-2010, 05:51 PM   #3
St. John , Indiana
I am not at all electrical, do you know where I would find one? Does it go in the breaker box? I have no idea how to change it! Any tips?
Jill
Old 08-08-2010, 06:06 PM   #4
Jim Rogers
jimrogers's Avatar
it is in breaker box,you can buy a breaker anywhere breakers are sold take old one with you.
frist disconnect trailer,should be a 20 amp going t o a.c. replace it with 30
Old 08-08-2010, 06:18 PM   #5
St. John , Indiana
Thank you very much for your help! If you don't mind, I have one more question. I don't know how to get them out. Do the fuses just pull out? I don't want to create another problem! Thank you for all of your help!
Jill
Old 08-08-2010, 06:25 PM   #6
Jim Rogers
jimrogers's Avatar
there is a wire you have to take it loose and pry it loose from top
Old 08-08-2010, 06:30 PM   #7
garry's Avatar
1969 31' Sovereign
Broken Arrow , Oklahoma
What else do you have on ???
Make sure the frig and hot water heater are on propane and not electric.
You can not run the AC, microwave or any other high amp draw at the same time.
Try running the AC on low.
What breaker is tripping the main or the 20 amp?
The AC should not trip the breaker but breakers do go bad.
Garry
Old 08-08-2010, 06:34 PM   #8
garry's Avatar
1969 31' Sovereign
Warning..... to be safe do not pull the breaker with power plugged in.
Normally the left side pulls straight out (you can use a screw driver to pry it) and the right side slips in 1st when you put it back. There is one black wire that has to be removed.
If you pull it make sure the wire is very tight when you reinstall.
Garry
Old 08-08-2010, 06:35 PM   #9
Moderator Emeritus
overlander64's Avatar
1964 26' Overlander
1978 Argosy Minuet 6.0 Metre
Anna , Illinois
Images: 183
Help i'm roasting
Are you sure that the voltage was high enough to support proper operation of your air conditioner in the campground? As hot and humid as it has been in the Midwest, it wouldn't surprise me if the voltage available in the campground may not have been enough. If you don't already have one, there is an inexpensive meter that you can plug in an outlet to determine if sufficent voltate is available - - it has a green are that is acceptable - - yellow that mean caution -- and a red that meand do not use senesitive appliances.
Good luck in locating your electrical gremlin!
Kevin
Kevin D. Allen
AIR #827
Old 08-08-2010, 06:35 PM   #10
banjobill
wmarsha's Avatar
2000 30' Limited
battle ground, , Washington
replacing 20 amp breaker with 30 amp is a no-no
Jill, circuit breakers are sized to protect the wiring in an Alternating Current system (AC). If you change out an existing 20 amp breaker (which will protect 12 gauge wire) with a 30 amp breaker (which is designed to protect 10 gauge wire), then you have a potential for fire. Please do not change it out. The RV air conditioning units I have seen require a dedicated 20 amp circuit. If the air conditioner is not performing correctly, then you should first have a qualified individual check out the voltage/current sizing of the circuit feeding the air conditioner. If all is okay with your AC system, then there is a malfunction within the air conditioner, requiring a qualified air conditioning technician to check it out. Sorry, there are no short cuts to trouble shooting this equipment.
ol bill
wmarsha is offline   Reply With Quote
Old 08-08-2010, 06:37 PM   #11
St. John , Indiana
None of the breakers are tripping. The a/c is just shutting off. When you mess with the knobs it will restart after 5 minutes or so. Do you think it is breaker related?
Jill
Old 08-08-2010, 06:41 PM   #12
St. John , Indiana
Thank you for that info Marsha! It is a brands new unit. I am clueless as to why it isn't working!
Jill
Old 08-08-2010, 06:53 PM   #13
garry's Avatar
1969 31' Sovereign
Sorry reread your post, I thought the breaker was tripping.
Could be a problem with the thermostat or overheating the compressor (low freon) or as someone else said low voltage at the CG pedestal.
Garry
Old 08-08-2010, 07:09 PM   #14
St. John , Indiana
So we just checked the amps and it is at 118 with the a/c on and 120 with it off.
Jill
NorCal : NorCal Spring Rally, Casini Ranch, April 15-17 Big Dee Forum Rallies & Meet Ups 731 04-30-2011 11:23 PM
