Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > Furnaces, Heaters, Fireplaces & Air Conditioning
Old 06-27-2004, 02:26 AM   #1
sovereign's Avatar
Profile:  mill springs , North Carolina
help! a/c comp.want start pictures
a/c was working fine last week, now when i turn it on , only the fan blows and the compressor want start?
sovereign is offline   Reply With Quote
Old 06-27-2004, 07:45 AM   #2
Well-Preserved
overlander63's Avatar
Profile:  1974 31' Sovereign
Somewhere , Over the Rainbow
Check this thread, good luck with it.
http://www.airforums.com/forum...ad.php?t=12213
(No Longer at Inland RV)
Old 06-27-2004, 01:01 PM   #3
uncleneal's Avatar
Profile:
That seems to be going around, Firday I had cold air, Saturday only fan. A/c is a Coleman Delta TX. I've only had the unit about 10 months, so have no history on it. Anybody know where I should start checking?
Neal
uncleneal is offline   Reply With Quote
Old 07-05-2004, 02:19 PM   #4
sovereign's Avatar
here are some pix i took of the a/c control box. can somebody tell me which relay is the start relay? etc.? and the transformer in the pix is it surpose to put out 24 volts? i checked the wires in the thermostat r,y and g and there is no voltage goinig to any of the wires help, please
ID:	7518   Click image for larger version
Old 07-05-2004, 02:28 PM   #5
Well-Preserved
Okay, first, check to see if you have 110v going in to the transformer. If you do, check to see what voltage you have coming out of the transformer. My unit is supposed to put out 12v DC. If you are geting nothing coming out, and 110 going in, the transformer is the culprit. If you are not getting 110 to it, check the breaker and make sure it is not tripped, or broken. You should get 110 AC between the outlet of the breaker, and the common wire.
Old 07-05-2004, 02:54 PM   #6
Pahaska's Avatar
Profile:  2005 28' Classic
Austin (Hays County) , Texas
Images: 13
Thermostat?
Make sure that the thermostat hasn't failed. Typically, on these units, the fan runs continuously and the thermostat cycles the compressor.
I had a thermostat on my previous trailer that wouldn't turn off except at precisely one point on the dial. If I iggled the knob, it would turn off. It could be as easily one that won't turn on.
John W. Irwin
2005 Classic 28 "Sabre-Dog III"
2007 Silverado 2500HD Duramax/Allison LTZ
WBCCI Region 9 Webmaster, #9632
Old 07-05-2004, 04:48 PM   #7
TomW's Avatar
Profile:  1967 26' Overlander
Huntsville , Alabama
You had to remove an access door to take the picture. Was there not a schematic on the inside of the door?. I hate to walk on Argosy20, but in my limited experience, thermostats are usually managed with 24 volts AC.
I think your start relay is the on the lower left of your picture judging by the wire colors. Can you take a bigger picture showing the wires exiting at the bottom? One set of wires will go to the compressor; The other set will go to the fan motor. My most recent experience with Airstream A/C had brown wires going to the fan motor capacitor.
Bear in mind I am an avid enthusiast, not a professional. But I will help if I can.
Tom
Old 07-05-2004, 05:49 PM   #8
Well-Preserved
Tom
Not a problem, Tom. Mine, for whatever reason, ran on 12v DC.
I just checked my home A/C, just because, and my meter says it is working with 27.5 volts. AC.
Old 07-05-2004, 06:14 PM   #9
sovereign's Avatar
i will take another pix tomorrow, when you check the voltage from the little transformer. do you have to disconnect it on one end? i took a volt meter and checked the wires inside the trailer at the thermostat {removed the cover of the stat} and got no voltage, with the unit on. also all of the fans , the one inside and out run
Old 07-05-2004, 09:33 PM   #10
davidz71's Avatar
Profile:  1986 25' Sovereign
Southern Middle , Tennessee
transformer wires
Sovereign,
The transformer is in the upper right hand corner of your first picture. Set your meter for AC voltage of at least 125 v. I had to go out to the trailer and look up the drawing I made before taking the transformer out. You will see yellow and red wires coming out on the right hand side of the transformer. On the left hand side you should see a white & yellow wire as well as a black wire. Check current across the white/yellow and black wires first. I think this is the 125 v. side. If it shows current going into those wires then you know that you have power there. Also look for a white tag on the transformer which might tell you which is the high voltage AC side. If it showed appx. 125 volts then go to the other side with the yellow and red wires. Set the meter for up to 24 volts DC and measure the current across them. If it shows less than 24 volts then it is suspect. I believe mine only showed 9 volts coming out of the transformer and none at the thermostat. If this is what you find, make a drawing of where everything connects, take out the transformer and hit a few electrical supply houses. I found 2 transformers, one of which was entirely too big to fit in the space and one that was just a little larger than the one I took out. I had to fabricate another mounting bracket but it was no trouble at all. Be extremely careful with your meter to be sure you don't ruin it or yourself.
Craig
AIR #0078
3.73 rear end
Mag-Hytec rear diff cover
Amsoil synthetics all around
Old 07-06-2004, 11:39 PM   #11
sovereign's Avatar
yaaaaahhhooooo!!!! i fixed it!!! but not without everybodys help. thanks everybody. it turns out that the little transformer was bad, 11o v input and 0v output.
Old 07-07-2004, 04:28 AM   #12
Retired Moderator
john hd's Avatar
Profile:  1992 29' Excella
madison , Wisconsin
Images: 40
hey ya gotta like that!
sure is less expensive than the answer most rv places would have given you!
john
you call them ferrets, i call them weasels.
Old 07-07-2004, 08:39 AM   #13
Profile:  Corona , California
All of the Armstrong airconditioners used a 24 VAC transformer for the wall thermostat.
Unfortunately, with some inexpensive volt-ohm-millammeters, you can set the scale to DC, and still measure AC. The reading will not be correct, but you will get a reading.
The two relays are fairly common, and can be purchased at most any Airconditioner or Refrigeration parts source. The physical size of the relay doesn't matter, but what does matter is the ratings, in volts and amperes.
Andy Rogozinski
Inland RV Center
Corona, CA
Inland RV Center, In is online now   Reply With Quote
Old 07-07-2004, 10:08 AM   #14
sovereign's Avatar
in my case , i set the meter both ways ,and still got 0 volts?but on the dc scale the meter was pegged on 15v and 150 when checking the 110 side, but was correct on the ac scale
Is A/C original? whistler Furnaces, Heaters, Fireplaces & Air Conditioning 2 01-19-2004 04:32 AM
34' Excella 1000 needs cooler A/C cjholloway Furnaces, Heaters, Fireplaces & Air Conditioning 4 11-17-2003 06:50 PM
understanding A/C options Lexxy Furnaces, Heaters, Fireplaces & Air Conditioning 24 08-02-2003 05:29 PM
A/C blowing the breaker Chuck Furnaces, Heaters, Fireplaces & Air Conditioning 13 07-08-2003 10:52 AM
Mediocre A/C Chuck Furnaces, Heaters, Fireplaces & Air Conditioning 4 07-07-2002 07:52 PM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
