Old 08-01-2013, 11:53 AM   #1
Jcashcollect's Avatar
1978 31' Excella 500
Kelowna , British Columbia
Help! 1974 a/c needs recharge
Need to recharge the a/c unit in a 1974 international. Guessing it's probably R12. Can I just add R13A to the unit. It says R12 replacement on the can. Or are there other problems I should be looking for. Blows great, just doesn't get cold.
TIA
Jcashcollect is offline   Reply With Quote
Old 08-01-2013, 12:07 PM   #2
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
TIA
If it needs a recharge, that means you have a leak in the system somewhere. The freon lines are supposed to be sealed, so you never need to recharge unless there's a leak.
Find the leak, fix the leak. By the time you've done that, all of the R-12 will be gone (if it isn't already), and you can start fresh with R-13A.
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Old 08-01-2013, 01:37 PM   #3
Belegedhel's Avatar
1973 21' Globetrotter
Houston , Texas
Has it ever blown cold? It could be that your compressor is not working, in which case, replacing the entire unit might be the most expedient way to go.
Belegedhel is online now   Reply With Quote
Old 08-01-2013, 03:15 PM   #4
DKB_SATX's Avatar
1976 Argosy 28
Alamo Heights , Texas
According to Andy at Inland RV, the old Armstrongs use R22, not R12. R22 is still available and can continue to be produced until 2020, after which time only recycled R22 can be used, according to the EPA. There are some refrigerants that claim to be direct replacements that turned up in a Google search.
ó David
Zero Gravitas ó 2017 Flying Cloud 26U | Il Progetto ó 1976 Argosy 28 Center Bath | WBCCI# 15566
He has all of the virtues I dislike and none of the vices I admire. ó Sir Winston Churchill
Old 08-03-2013, 09:28 AM   #5
WBCCI 8562
Jim in Pima's Avatar
1975 31' Sovereign
Pelzer , South Carolina
Researching what it would take to recharge my Armstrong I found many of
the R22 replacements are made of flammable gas and not legal for "on the road"
use.
Jim in Pima Az, enjoying our 1975 31 ft Airstream Sovereign
Jim in Pima is offline   Reply With Quote
Old 08-03-2013, 10:17 AM   #6
Airstream air conditioners "all" use R-22 Freon.
R-12 was used in car and truck AC's.
