Old 10-30-2014, 10:18 PM   #1
Larkspur , California
Heating question..
In our 21014 25' flying cloud is it possible to turn off ducts in dinette and bathroom area while we are in bed? We're dry camping and would like to save the electricity and propane..We have a Dometic thermostat that includes 'programs" but we are puzzled at how to 'program"..any suggestions?
jpfromla is offline   Reply With Quote
Old 10-30-2014, 11:58 PM   #2
Gsmblue's Avatar
2015 25' Flying Cloud
Bend , Oregon
No it is not. The ducts are all connected. The programing function is to set up what temperature you want at what time.
http://britishairstream.blogspot.com
Mad Astrophysicist turned sales guy that works to fund his dirty snowbaording habbit, mwah-ha-ha . . .
Gsmblue is offline   Reply With Quote
Old 11-01-2014, 08:52 AM   #3
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
Your furnace needs to dump the heat it generates or it will overheat. My furnace requires something like 40 square inches of open duct space to exhaust heat, and about that much for the cold air return.
You can turn your thermostat down and find a warmer blanket until morning. And some boondocking folks like the catalytic heaters that don't use any electrical energy at all.
Your furnace needs its air flow.
David
Old 11-01-2014, 11:31 PM   #4
Gsmblue's Avatar
Bend , Oregon
The furnace does not use the new overhead ducts, only the heat pump/AC does.
Old 11-02-2014, 02:26 AM   #5
Msmoto's Avatar
2015 30' International
2009 27' FB International
2007 25' Safari
Greensboro , North Carolina
Images: 135
Is the issue of saving propane based upon the length of time you are dry camping and you have concerns about running out, or is it just a cost idea? The batteries should easily be able to cover for one night, then run the generator the next day or use solar to recharge.
In newer Airstream TT, there are some items such as televisions, subwoofer, and possibly others which use electricity even when turned off. When dry camping make certain you do not have anything plugged in to the inverter circuit that you are not actively using.
Ms Tommie Lauer
Greensboro, NC
2015 Serenity 30 RB / 2008 Dodge Cummins 4 X 4
WBCCI #4165 AIR #31871
Happy trails and Good Luck
AIR #31871 K4MTL
www.fantinesvoice.com
Msmoto is offline   Reply With Quote
Heating and AC question.. Rofkrynn 1974 Overlander 2 05-09-2013 01:54 PM
UK heating question 3 Dog Nite Furnaces, Heaters, Fireplaces & Air Conditioning 0 03-02-2011 10:05 PM
Water heating question Ellie & Carl Furnaces, Heaters, Fireplaces & Air Conditioning 13 04-08-2010 09:54 PM
Mister Heater/cheap heating options? Dave Cole Furnaces, Heaters, Fireplaces & Air Conditioning 5 12-14-2002 02:03 PM
Refrig. Heating Up rroessler Refrigerators 15 08-07-2002 05:46 PM
