Old 04-02-2012, 09:05 AM   #1
AirHeadRik's Avatar
Castaic , California
Images: 13
Heating/Air on a 2010 International
Hoping someone can offer some advice.
I set the thermostat program 1 to 72 degrees and 2 to 74 degrees. Wanted to make sure it switched over ok. All good, but now I have water on the floor under the air conditioning unit. I know sometimes it uses hear from that unit. Is it condensation? I'm fairly mechanically inclined, but with heat and air I'm sort of a moron.
Please help!
2011 International 25' Signature Series
2010 Dodge Ram 1500
Pro Pride Hitch
AirHeadRik is offline   Reply With Quote
Old 04-02-2012, 09:24 AM   #2
tpi
Trabuco Canyon , California
I just had mine repaired for that. It was a cracked plastic condensate pan under the air conditioner. It would also drip when it rained (depending on wind, etc.). You may also want to give the three hold down bolts a turn or two, but don't overtighten! They are not meant to be very tight. Check Dometic documentation for specs and procedures.
Before it cracked, I did have occasional drops of water under the AC when the outside weather was rather humid and cool, and door/windows frequently open. Excess moisture was condensing on the cold inner surfaces of the AC unit.
If I were in your shoes, I'd watch it for further drips, especially when it rains, or humid weather w/ AC use. Mine would take more than an hour of use to start the dripping. If it drips, suspect strongly the condensate drain pan. This seems to crop up as a frequent problem. If its under warranty, confirm problem and take it in for repair.
tpi is offline   Reply With Quote
Advice on repainting an Argosy jimin pa Clearcoat, Exterior Paint & Trim 13 08-03-2013 07:21 AM
TX Veteran Designation on Drivers License Bluto Off Topic Forum 43 06-27-2012 12:31 AM
Suggestions for South Carolina RV parks on beach? Lothlorian Airstream Lifestyle 25 04-14-2012 07:36 AM
Basic questions on applying Parbond and Vulkem Jammer Leaks - Weatherstrips, Gaskets, Caulks & Sealants 7 04-02-2012 07:01 PM
