Old 09-26-2010, 04:14 PM   #1
1978 25' Tradewind
Louisville , Colorado
Heater Problems
I have a 1977 Tradewind 25' with a problem heater. I have the propane on. I have electricity to the heater. When I throw the thermostat on, the blower just blows cold air. The heater is not igniting. I have opened the heater and I can see two wires going into the heater to two insulators. There is a third (ground?) wire attached only to the metal shell of the heater, where does this go? why wont it ignite?
twilight10 is offline   Reply With Quote
Old 09-26-2010, 08:15 PM   #2
Ganglin's Avatar
1971 27' Overlander
Central , Ohio
Images: 13
How long did you let it run? The first time we fired ours up to test it it took at least 3 or more minutes before it fired up....
Old 09-26-2010, 08:25 PM   #3
1978 25' Tradewind
Yeah, I let it run 15 minutes. No Go
Old 09-26-2010, 10:14 PM   #4
purman's Avatar
1968 28' Ambassador
Cedaredge , Colorado
There is a switch that lets it now when the fan is running sometimes it goes bad and it won't let the propane through to light. Can you here the igniter going click click click?
Jason
2008 5.7 L V8 Sequoia
AIR # 31243
WBCCI # 6987
FOUR CORNERS UNIT
Old 09-26-2010, 10:18 PM   #5
Full Timers/Diesel power.
Mike Leary's Avatar
Cactus Hug , Arizona
Images: 11
What brand of furnace is it? If it's a Suburban, I know WAY more about them than I should!
"A settled wisdom, plus the itch to be elsewhere"
Mike Leary is offline   Reply With Quote
Old 09-26-2010, 10:28 PM   #6
x
XXXX , XXXX
Twilight10 if this is the original furnace then it is a pilot light model. You must first light the pilot light manually. Once the pilot light is light and you turn up the thermostat the fan will run and the burner will ignite. There may also be a shut off valve adjacent to the furnace on the copper propane line. Make sure it is open.
Can you post pictures and the model number of the furnace. This will help us determine which type of furnace it is. Can you see a circuit board attached to the furnace or a multi wire harness going into the furnace case?
wasagachris is offline   Reply With Quote
Old 09-27-2010, 09:17 AM   #7
1978 25' Tradewind
Ok it is a Surburban model T-7 I just hooked the AS up to 110V AC, threw the switch, and she, the heater, lit up like a dream. I'm now thinking it's the battery. I disconnected the 110V AC and tried it- no go The Battery was down to 45%. Now recharging the batteries.
Old 09-27-2010, 02:33 PM   #8
1978 25' Tradewind
Ok , so it now starts with a fully charged battery. I think the problem is solved.
I need a pretty full battery in order to ingite the furnace. or so it seems...
heater
JC With Problems, Same Problems Goin Home ncbambi 2008 Safari SE 3 06-23-2009 09:44 PM
New Water Heater problems jpancini Water Heaters, Filters & Pumps 8 08-05-2008 09:51 PM
Update on Problems Problems pjude General Motorhome Topics 4 09-04-2007 06:02 AM
Water heater problems... kayamtom Water Heaters, Filters & Pumps 9 03-19-2007 05:22 PM
Water heater, toilet problems on a MH zduke4x Water Heaters, Filters & Pumps 2 06-07-2004 03:20 PM
