Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > Furnaces, Heaters, Fireplaces & Air Conditioning
Old 09-14-2006, 01:36 PM   #1
piratesteve
piratesteve's Avatar
Profile:  1958 18' "Footer"
idyllwild , California
Heater Knob
I'm most likely being too cautious but;
I need to remove some cabinetry to replace the linoleum on the 1958 18'. There is a Glen Air Furnace that I need to remove. It works fine so I don't want to break the plastic knob to turn it on or off. Does this knob just pull off or is there a secret handshake?
Steve
piratesteve is offline   Reply With Quote
Old 09-14-2006, 02:12 PM   #2
RV_cool
Commercial Vendor
Profile:  Currently Looking...
east stroudsburg , Pennsylvania
Steve
look carefully around the entire knob to see if there is a set screw holding it. If you don't see any it should just pull off.
RV_cool is offline   Reply With Quote
Old 09-14-2006, 06:55 PM   #3
piratesteve
Thanks for the help, I was able to get it off with no visual damage.
I pulled the metal cap off of the plastic knob, dilled a hole in the middle to see the shaft and was able to tap the shaft with a punch. Everything looks like it did befor I started.
Steve
Water Heater Craig 1978- 1979 Excella 500 7 10-01-2007 05:16 PM
wiring - water heater Craig Electrical - Systems, Generators, Batteries & Solar 12 10-02-2002 05:03 AM
Hot water Heater DClark Water Heaters, Filters & Pumps 11 08-26-2002 06:04 PM
Water Heater shell frame BobbyW Water Heaters, Filters & Pumps 0 04-29-2002 10:21 AM
Water heater work tool FrankR Water Heaters, Filters & Pumps 1 04-09-2002 10:57 AM
