Old 12-09-2015, 07:00 AM   #1
2012 27' FB Classic
Portland , Oregon
Heater fan maintanence ?
Lately my furnace fan has developed a sound when the furnace cycles off.
Before you could not hear the rotation of the fan. Now it sounds like it is very lightly scrapping on something or that there is a bit of sand in the bearings.This sound is only during the last few revolutions before it comes to a stop at the end of its cycle when the heater shuts off. Does this simply need maintenance or is this an indication of something else? My 2012 Classic has a Atwood blower motor.
Any feedback would be welcome !
Airtrekker is offline   Reply With Quote
Old 12-09-2015, 08:00 AM   #2
Mission , Texas
Clean the fan and check the fan shroud.
If it were the bearings it would probably always be noisy.
More likely it is a little dirty and so possibly slightly off balance which is only noticeable as it winds down. Later the bearings go out.
nrgtrakr is offline   Reply With Quote
Old 12-09-2015, 08:02 AM   #3
Ron A's Avatar
2018 23' Flying Cloud
Huntsville , Alabama
I'm sorry I have not experienced the same problem, however, I'm sure someone will come along shortly that can assist. I have certainly learned a lot from the people on this forum.
Ron
Ron
Ron A is offline   Reply With Quote
Old 12-09-2015, 08:05 AM   #4
2016 30' Classic
Erie , Colorado
May be that the sail switch is touching the fan blades. Easy check is to rotate the fan by hand. Typically this would be clockwise. One way to test is to turn off the reset switch when you have the outside cover removed, set the thermostat so that the furnace will come on and then you can turn it on and off with the reset switch while you listen/watch the furnace.
Gary
2015 Classic
2015 GMC Sierra 2500HD Duramax
ProPride
NVPN
ghaynes755 is offline   Reply With Quote
Old 12-09-2015, 01:15 PM   #5
2012 30' Classic
Ocala , Florida
Mine was doing the same thing. I tried to adjust the noise out. Could not get it out. I was at JC and they replaced fan blade. The noise has not come back .
Kenaisalmon is offline   Reply With Quote
Old 12-14-2015, 09:04 AM   #6
2012 27' FB Classic
Portland , Oregon
Thank you !
Thank you one and all !!! This is all very helpful !
Fan-Tastic fan install Gordon Watt Roof Vents, Skylights & Fans 28 08-15-2011 11:41 AM
Fan-tastic Fan Installation With Photos Dabler Roof Vents, Skylights & Fans 9 09-09-2007 08:18 PM
Fan-Tastic fan??? definition needed hex Our Community 26 10-10-2002 02:17 PM
Fan-tastic Fan installation BobbyW Roof Vents, Skylights & Fans 4 06-17-2002 09:40 PM
