Old 02-05-2007, 03:26 PM   #29
Pop Rivet's Avatar
1990 25' Airstream 250
Altoona , Georgia
the amount of current the fan motor draws is a function of how much air the fan is moving and at what air pressure. If you are measuring the current with the fan removed from the furnace and distribution system, the current (amps) should read very low. If the fan is installed in the system and the air outlets are blocked, the current will read low. If the fan is running backwards, the current will read low.
Pop Rivet is offline   Reply With Quote
Old 02-05-2007, 05:52 PM   #30
It sounds like the problem has been solved. Thanks again to everybody for their help and advice. I would be lost without this great forum and community.
Thanks again,
Greg
85Sovereign is offline   Reply With Quote
Old 02-05-2007, 06:03 PM   #31
INSANITY CENTRAL
doorgunner's Avatar
1986 32' Excella
2014 Interstate Ext. Coach
Citrus Heights , California
Images: 35
Greg, I'm curious-m could you reinstall the the old motor with the gravel in the bearings and take a reading again. Just wondering how much the drag would effect the amp draw!! Glad you got it repaired
www.popasmoke.com
Proud Appellation American
Vine View Heights is now closed.
YETI ( 65 Quart )
IGLOO (Ice Cube, 50 Quart )
doorgunner is offline   Reply With Quote
Old 02-10-2007, 07:17 AM   #32
That was an idea I had as well. But, I let one of my knuckle headed friends open the motor up. He beat on it with a screwdriver and some little springs fell out that I could never get back in around the brushes. Needless to say I destroyed these little springs when I thought I had it back together correctly. I even found a source for replacement bearings here in OKC. But, I did not pursue the new bearings since I could not find any new springs. So, I think it would be a good motor if I could just find those little springs again. Anybody know where I could get a rebuild kit?
Greg
Old 02-20-2007, 05:38 AM   #33
lewster's Avatar
Naples, FL , Hood River, OR
David,
It has been my experience that a fan running in a closed system with the air outlets blocked will have a HIGHER amperage reading due to the back pressure created by the lack of outlets, causing it to work harder while attempting to move the air. The statement about the free air reading is correct.
The same goes for A/C compressors. We use amp readings to determine if the compressor is working properly or if the sealed refrigerant system has had a leak, in which case the system has little or no back pressure and shows a much lower amp draw than the operational rating.
Old 02-20-2007, 06:40 AM   #34
Pop Rivet's Avatar
Altoona , Georgia
Originally Posted by lewster
David,
Hmm - I can tell you this - I enjoy your posts and like your thinking but regardless of your experience. work is a function of force x distance and if you are not moving the air, you are not doing any work. Power is the rate work is being done - power equals work/ time. Watts is the term used to define electrical power and is a function of volts x amps. Years ago I did air balences on large HVAC systems and I can assure you that as the air flow dampers were opened up and the air movers moved more air, the current readings went up. One of the controlling factors was the motor current as you could overload the driver by moving too much air.
I look forward to meeting you at Springstream.
Old 02-20-2007, 06:57 AM   #35
fastrob's Avatar
1976 25' Tradewind
. , AZ to Maine
Current Thoughts
Please explain: Current, Voltage and Amperage
I thought current was the flow of electrons. Voltage is the size of the pipe carrying the electrons and Amperage is the amount of pressure behind the pipe, using the water pipe analogy.
Is that correct?
So, if there was no back pressure on the heater fan the current would flow higher, within the limits of the wire or pipe? The amperage would be lower?
If there was back pressure on the fan causing the fan to work harder the current flow would be lower but the amperage or backpressure would be higher due to the increased work by the fan?
I know it is not voltage, it is amperage that kills you.
Rob
fastrob is offline   Reply With Quote
Old 02-20-2007, 07:14 AM   #36
Pop Rivet's Avatar
Altoona , Georgia
Is that correct?
Rob
You are close - Voltage is electrical pressure. Current is the flow of electrons.
Amperage is the measure of current. E (Voltage) = I (current) x R (resistance) so e= IR, I= E/R, R= E/I. Watts or power equals volts x amps.
If you have a electric pump with a discharge valve and put an amp meter on the motor cord, As you open the discharge valve, the motor amps will increase. Some large pumps have a interlock that requires the discharge valve to be shut during motor starts to prevent motor overload.
Hot water Heater DClark Water Heaters, Filters & Pumps 15 08-25-2017 02:35 AM
Water Heater Craig 1978- 1979 Excella 500 7 10-01-2007 05:16 PM
Repair or Replace Original Bowen Water Heater? Andy R Water Heaters, Filters & Pumps 8 11-16-2005 03:51 PM
wiring - water heater Craig Electrical - Systems, Generators, Batteries & Solar 12 10-02-2002 05:03 AM
Water Heater shell frame BobbyW Water Heaters, Filters & Pumps 0 04-29-2002 10:21 AM
