Old 10-28-2008, 10:37 PM   #1
1975 27' Overlander
saucier , Mississippi
Rivet Heater
Hi I have a 1975 int 27ft i want to upgrade to a newer better furnace but dont no what will fit is it a major mod or do they make a direct replacment or something close with all the new stuff like auto lighting and what not the one that is in it now is a surbaban dont no the model any help would be great
clinton2292 is offline   Reply With Quote
Old 10-29-2008, 07:00 AM   #2
Silverhobby's Avatar
1967 26' Overlander
1968 30' Sovereign
Mosheim , Tennessee
If yours is the original furnace, it is most likely an NT series furnace by Suburban. The dimensions may have changed slightly, but the Suburban is still the best candidate for a replacement. I had to slightly modify the ductwork and mounting area when I installed a new furnace in a 1965 Safari, but it was a rather easy job. For your trailer, check out the Suburban NT30SP. This is rated at 30,000 BTUs. Unit size is 12 1/2" x 12". Best of luck to you.
//------AIR # 7303------\\
WBCCI 17109
visit my restoration blog at:
Old 11-07-2008, 07:40 AM   #3
WBCCI 8562
Jim in Pima's Avatar
1975 31' Sovereign
Pelzer , South Carolina
About to change the furnace in my 1975 Sovereign, bought a NT30,
old one was a NT32 both ducted. Question, the large steel case the old furnace was in, can I leave it?? Do I need to cut some additional vent holes, seems it would be a huge project to remove. Gas line just needs to be cut off and new fitting flanged on.
THanks
New WBCCI 8562
Jim in Pima Az, enjoying our 1975 31 ft Airstream Sovereign
Jim in Pima is offline   Reply With Quote
Bowen water heater door with newer suburban water heater durans54 Water Heaters, Filters & Pumps 37 11-19-2008 07:17 AM
heater help trea LP Gas, Piping, Tanks & Regulators 7 10-21-2006 02:24 AM
Water heater prob, pilot won't stay lit & heater won't fire. johnboy Water Heaters, Filters & Pumps 1 06-20-2006 04:24 PM
water heater and heater cabbage76 Furnaces, Heaters, Fireplaces & Air Conditioning 7 11-12-2003 08:06 PM
under the heater Phaedrus Repairing/Replacing Floor &/or Frame 0 05-09-2003 11:38 PM
