Old 03-04-2016, 02:49 PM   #1
1968 22' Safari
Dorchester , Illinois
Heater
We've owned our 68 Safari for 12 years and never tried out the furnace. A couple of electric heaters worked OK. Main reason I haven't tried it was the mud dauber nests in the air/exhaust ports. I cleaned what I could out and screened off those areas but not sure what to do next. I'd like to use it at times, so how do I proceed? Furnace is located under sink so all access is via laying on the floor with a flashlight and bifocals so please someone give me a tutorial on checking out this furnace.
Thanks, Steve
Missed-Em is offline   Reply With Quote
Old 03-04-2016, 03:37 PM   #2
sgschwend's Avatar
1986 25' Sovereign
2008 F350, 6.4L diesel , Oak Harbor, WA
Images: 13
Yes, mine is located there too:
The furnace likely will run this process:
With the thermostat turned on the heater will switch the blower on and run for several seconds, then it will try to light itself from the propane tank, you should be able to hear the gas valve open, and then several clicks from the electric starter.
You appliance will have a shutoff valve at the lower right front corner. If the valve has been on all this time then with your propane tanks on it will likely start.
If the blower keeps running it is likely running. You can go outside and checkout the temperature of the exhaust. The rule is to have nothing, including your door in front of the exhaust.
Now I can't tell you about the condition of your unit. Are there cracks in the heat exchanger for example. If so then the unit is not safe and is past a usable state and needs to be replaced. You could try a gas detector to determine if you can find a gas leak, which could either be propane or combustion products. Unfortunately either leak show presence differently. Propane near the floor and CO near the ceiling.
Or you can remove the five or seven outside screw and then from the inside take the front cover off. You will find two wood screws holding the heater to the floor. Then spin off the vents, close the gas valve (front right corner), disconnect the gas line and the unit will come out. You could then put the furnace on your work bench and inspect the unit. Taking the cabinet off isn't that much more work, which will improve you inspection. When I did this on my 1986 unit I found the unit was rusted out. Once again don't bother to try and have the metal repaired.
sgschwend is offline   Reply With Quote
Water heater/ heater matrix repair montreal Classic Motorhomes 2 06-08-2012 06:00 AM
Propane Heater or Instant water heater valontjej Plumbing - Systems & Fixtures 1 04-09-2012 08:56 PM
Bowen water heater door with newer suburban water heater durans54 Water Heaters, Filters & Pumps 37 11-19-2008 07:17 AM
Water heater prob, pilot won't stay lit & heater won't fire. johnboy Water Heaters, Filters & Pumps 1 06-20-2006 04:24 PM
water heater and heater cabbage76 Furnaces, Heaters, Fireplaces & Air Conditioning 7 11-12-2003 08:06 PM
