Old 12-24-2009, 10:00 AM   #1
bwaysteve's Avatar
1965 28' Ambassador
Irving , Texas
Heat vent on skin
Replacing the old International Oil Burner with something current.
Can I retain the vintage outside vents on the skin?
bwaysteve is offline   Reply With Quote
Old 12-24-2009, 10:51 AM   #2
easyride's Avatar
1977 27' Overlander
1963 19' Globetrotter
Naples , Florida
You must have another trailer,that 65 didn`t come with an oil heater,anyhow if you are installing a free standing propane gas heater.1 Combustion air should be ample air flow,from what I have seen on the old oil burners they had quiet a large area for com.air,you may want to duct it down and feed it closer to the burner.2 The vent should work as long as you don`t have to bush down to connect,bushing up is fine. Hope this helps. Dave
PS Do you have a picture of the oil burner,I need 1 for my 48 Spartanette? Dave
easyride is offline   Reply With Quote
Old 12-24-2009, 10:56 AM   #3
Modifying the intake or exhaust system of anything that could contribute to improper fuel burning, or carbon monoxide gases, or even an explosion, is not a very wise idea.
Granted, the looks would be great.
And the related "hazards" are equally if not greater.
Not worth the risk, to you, your family and/or others.
Old 12-24-2009, 11:12 AM   #4
goransons's Avatar
1963 22' Safari
1955 26' Cruiser Overlander
Yakima Valley , Washington
Send a message via MSN to goransons
vents
I agree it has to be done very carefully as not to restrict flow etc. We're running a suburban furnace and a new water heater in the 63, but using all the original exterior vent covers. My appologies to the builder that did this originally, I can't remember. I'll look back to make sure to credit their great work, but here's what they did.
Another option if not able to maintain airflow would be to make the cover removable in much the same fashion, but there for show when off, then easy to pivot open or remove entirely during use.
ID:	92986   Click image for larger version
Scott & Megan
VAC LIBRARIAN
Restoring Wally Byam's 1955 26' European Caravan Trailer!
WBCCI 8671
1963 Safari from the 1963-64 Around the World Caravan
goransons is online now   Reply With Quote
Old 12-24-2009, 11:19 AM   #5
Originally Posted by easyride View Post
You must have another trailer,that 65 didn`t come with an oil heater,? Dave
Dave.
Airstream never used an "oil" heater.
But they did use a LPG furnace made by a company called "International Oil Burner".
That company should have stayed with the oil burner heating systems, since they created a super "JUNK TYPE" LPG furnace.
There was something like a dozen modifications to it, "while still in it's very short warranty period".
Today, they are an absolute "EXPLOSIVE HAZARD" as they were over 40 years ago.
Old 12-24-2009, 11:38 AM   #6
Images: 59
Not only that, they weighted about a ton because of the transformer they used to step down from 120v.
Old 12-24-2009, 12:27 PM   #7
easyride's Avatar
1977 27' Overlander
Naples , Florida
Oil burner
Dave.
Thanks for clearing that up for me,knew I had never seen a fuel oil heater in an Airstream. Dave
Old 12-27-2009, 04:20 PM   #8
bwaysteve's Avatar
1965 28' Ambassador
Irving , Texas
This looks gret and would work safely no doubt.Do you have any pics of the furnace side?Thanks!
Old 05-30-2011, 12:28 PM   #9
Evergreen , Colorado
Dave.
Andy,
We recently purchased a 65 Overlander with the original International heater. It works fine. Are you saying they are unsafe? Do you recommend replacing it? We are in Colorado and expect to camp in cool fall months. Thanks! Nigel
Nigel is offline   Reply With Quote
Old 05-30-2011, 12:45 PM   #10
Originally Posted by Nigel View Post
Andy,
DO NOT fire that furnace up.
They have a huge problem by EXPLODING.
Replace it with a Suburban.
If you take that old furnace apart, you will immediately go for a huge drink, and thank your lucky stars, after you see the internal mess.
Old 05-30-2011, 05:38 PM   #11
Vintage Kin
slowmover's Avatar
Fort Worth , Texas
Lewster [RV tech] makes mention that he won't/can't work on propane furnaces older than 15-years due to liability. While many older furnaces are low-hour usage (and I've seen posts where some -- skilled -- overhaul them), I think the 15-years and out "rule" to be a good one. There's a reasonalble limit even on propane ones from 1996 by this.
Thanks, Andy. Whew, glad I don't have one of those IOB units!
Using the heat pump/heat strip instead of furnace. crazylev On The Road... 38 10-28-2016 07:58 PM
louvered stainless steel vent or chrome vent toastie Roof Vents, Skylights & Fans 0 10-18-2009 04:01 PM
Loosening Vent Handles and Aluminum Vent Replacement kincaidjesse Roof Vents, Skylights & Fans 4 04-16-2007 10:37 PM
Sealing exterior skin panels with Lizard Skin BB 55 Bubble Leaks - Weatherstrips, Gaskets, Caulks & Sealants 15 11-21-2006 04:50 PM
The Heat is ON!! GlenCoombe Mechanics Corner - Engines, Transmission & More... 5 10-09-2005 03:48 PM
