Old 11-10-2018, 08:28 AM   #1
2018 30' Classic
Carlisle , Pennsylvania
Heat pumps won’t start
Both our roof heat pumps won’t start. It’s 39 in the trailer heat pumps are set to 67 I can hear them “click “ when I switch from auto or low or high both won’t start plugged into my home 30amp. Only run one at a time. They always worked before now neither one will run. What am I simply overlooking?
mike2 is offline   Reply With Quote
Old 11-10-2018, 08:31 AM   #2
Well Preserved
overlander63's Avatar
1993 21' Sovereign
Colfax , North Carolina
They won't turn on if the outdoor temp is below 35-40. How cold is it outside?
https://www.gofundme.com/marie039s-o2-amp-dialysis-fund
Old 11-10-2018, 08:31 AM   #3
Adventure.AS's Avatar
2017 25' International
Port Dover , ON Canada
What is the outside temperature?
Ray B.
“One test is worth a thousand 'expert' opinions”
Sign at Boeing headquarters, posted by test pilot Alvin “Tex” Johnston, c1948
Adventure.AS is online now   Reply With Quote
Old 11-11-2018, 08:18 AM   #4
2018 30' Classic
Sorry for the delay... thanks, yes it was in the 30s and high wind so windchill was even lower. I’m glad it’s programmed like that and not a issue. Thanks for your response
Old 11-11-2018, 08:20 AM   #5
2018 30' Classic
Sorry it was in the low 30s plus wind
Old 11-11-2018, 07:39 PM   #6
jcanavera's Avatar
2004 30' Classic Slideout
Fenton , Missouri
Images: 143
Yep there is a point of diminishing returns where a heat pump will no longer be able to extract enough heat from the outside air to give you adequate heat discharge.
The other thing is that those outside coils that usually are hot in the summer, exhausting the heat from inside the trailer are now cold instead. Depending upon the outdoor humidity the outside condenser can form ice. That's why most heat pumps go into a reverse mode after a certain amount of run time, to clear the ice off the outdoor coils . In extremely humid situations and colder out door temperatures, there also is the possibility of the defrost cycle not being long enough and your coils may ice up. We had this happen in Branson once on a cold rainy day. We came back to the trailer and found the trailer cold inside. I went outside and noticed the outdoor coils were completely white with ice.
Jack
Jack Canavera
STL Mo.
AIR #56
Old 11-12-2018, 01:44 AM   #7
"Space A" S/O Registry 11
2006 34' Classic S/O
Fort Worth , Texas
Shouldn't the furnace come on when it is too cold for the heat pumps? Mine does.
Heat Pumps on a Classic 30' 2018 Airhead2018 2016 - Current Classic (all lengths) 17 02-15-2018 07:13 AM
Soft Start - Easy Start - Smart Start..? JConsroe Generators & Solar Power 13 06-16-2017 08:36 AM
Why do they put heat pumps in trailers? Bill M. Airstream Lifestyle 23 02-26-2014 03:27 PM
Thermostat-Dual Heat Pumps carlose Electronics & Connectivity 0 10-09-2011 05:02 PM
Heat Pumps Brianv512 Furnaces, Heaters, Fireplaces & Air Conditioning 8 01-19-2011 06:15 PM
