Originally Posted by Rugger
I just started using my heat pump and am finding that it ices up after about 6 hours of run time. It heats my rig up to the set point (about 68 degrees) with the outside temp of about 40 degrees. The manual says that the unit shuts off for about 4 1/2 minutes and reverses the flow to defrost the outside coils once the outside temp drops below 41 degrees. I hear my unit doing this, but it doesnt seem to run long enough to fully defrost the unit. Once the unit ices up, it severly limits the amount of heat it puts out. I can see the ice on the coils. Im in the desert, so the air is relatively dry. Any suggestions?
Once you have severely iced it up you need to run the AC for a while. If it continues; the freeze senor has fallen off, failed, or the control board has failed. It
Depending on what you have for a thermostat, mine switches over to furnance at 40 degrees.
