Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > Furnaces, Heaters, Fireplaces & Air Conditioning
Prev Previous Post   Next Post Next
Old 06-04-2008, 08:54 PM   #1
Profile:  1973 23' Safari
northfield , Massachusetts
heat pump or a/c unit
pro and cons of each. was going to order 11,000 btu low profile penguin a/c unit . but carrier unit 640.00 penguin unit almost 930.00 with drip pan.guy on phone wasn't even sure if it was right.so I'm going with carrier.
any help would be appreceated........thanks Don
twiggy137 is offline   Reply With Quote
Using the heat pump/heat strip instead of furnace. crazylev On The Road... 37 07-16-2009 10:08 PM
should i get the a/c with the heat pump?? evelitalian Furnaces, Heaters, Fireplaces & Air Conditioning 37 04-22-2008 07:17 PM
Stand Alone Heat Pump? Hamb7 Furnaces, Heaters, Fireplaces & Air Conditioning 1 06-04-2007 08:04 AM
Heat pump switched on in AC mode Pahaska Furnaces, Heaters, Fireplaces & Air Conditioning 11 05-22-2005 09:09 PM
Heat Pump and Furnace Operation Cracker Water Heaters, Filters & Pumps 21 12-10-2003 04:10 PM
