Just an update as I diagnose this issue.
The reset on the Comfort Control Center did not cure the issue.
Checked with Dometic, they advised the unit should switch from heat pump to furnace below about 30 degrees. My problem is likely the ambient sensor (like a thermostat which tells the heat pump to switch to furnace) has failed.
I took the cover off the heat pump/AC unit on the roof and located the sensor.
I have attached a photo....it is the yellow bulb in the left center of the photo. It has a white wire which runs to a red plug and plugs into the P3 slot on the board.
Next step is to get the part number and order a replacement.
The saga continues.....
