Hi we have a 2019 23CB and are using the heat pump at night. We have 30 amp service, the temperatures at night are in the low 40s . When it starts there is a long hum , about 35 to 45 seconds then the system starts to blow air. Normal?
Then when on, there sounds like door flaps are shutting shut. Pretty loud
Took it in to our dealership, could not duplicate. Any ideas?
2019 GMC Sierra Denali
2019 23CB International
2019 30' International
Pennsylvania
, Pennsylvania
That first sound you describe I would think is normal, the door flap sound is unfamiliar to me though. Our heat pumps go through differing cycles, including defrost cycles, and make some differing sounds as a result. No slapping or slamming of doors for us though
[QUOTE=LuckyCloud;2196624]Door flaps... multiple locations? There’s a range hood vent cover on the outside that might be exhausting some air?
I thought the range hood door flap was a stretch but I still had to rule it out. I locked it in place and turned the heat pump on and the noise is still there.
Thanks for the tip, trying to rule things out.
1997 30' Excella
1954 22' Flying Cloud
1981 28' Airstream 280
San Antonio
The hum on start up is normal.
The other noise is when it goes in and out of defrost. It is the switching valve. If you don't want to hear this, supplement your heat pump with a small ceramic heater. HP won't go in and out of defrost as much.
Bruce WBCCI# 9259AIR# 38927TAC-TX 14 Stop Littering-Spay & Neuter-- Adopt From Rescue No amount of time will erase the memory of a great dog.
