Old 09-08-2014, 05:37 AM   #1
Aluminum Condo III
kamadeca's Avatar
2015 30' International
Saskatoon , Saskatchewan
Heat Pump & Furnace
Hi folks,
We are having an interesting "undocumented feature" with our new 2015 30' International. When we turn the furnace on the Heat Pump comes on as well. Has anyone else experienced this and how do I get only the furnace to come on? This is especially annoying when we are boon docking and running off the solar panels. The HP will drain the batteries in no time!
Thanks as always
Malcolm & Randy
WBCCI # 12523
kamadeca is offline   Reply With Quote
Old 09-08-2014, 06:01 AM   #2
Aluminum Condo III
kamadeca's Avatar
Answering my own Question
Amazing what you can find on the internet. After I posted the question I thought I would do a search on the internet - I found my answer!
It seems that if you have the fan in anything other than the "Auto" setting (i.e. Hi, Med, Lo), the HP will come on with the furnace. Set the fan to Auto and only the furnace comes on.
Now who designed that system?
Thanks for looking!
Malcolm & Randy
WBCCI # 12523
Old 09-14-2014, 02:41 PM   #3
Larry C's Avatar
1996 34' Excella
Elberta , Alabama
Thanks for looking!
You must have a lot of battery capacity and a large capacity invertor to run your heat pump when your boondocking....just sayin'
Larry C
Old age is coming at a really bad time!
1996 34' Excella 1000, interior totally redone, 2003 Dodge/Cummins HO, U.S. Gear exhaust brake, Diablo tuner, 115 gallon aux fuel, Bedslide, Airsafe/Reese Dual Cam, and a bunch of other stuff
Larry C is offline   Reply With Quote
Old 09-14-2014, 02:56 PM   #4
terryV's Avatar
2002 31' Classic
Monroe , Iowa
Thank you for that. I didn't know that either. Now, because of you' I do.
terryV is offline   Reply With Quote
Heat pump or heat strips? coolwhip40 Furnaces, Heaters, Fireplaces & Air Conditioning 17 05-03-2018 09:27 AM
Using the heat pump/heat strip instead of furnace. crazylev On The Road... 38 10-28-2016 07:58 PM
To heat pump, or not to heat pump, that is the ?? MacDad Furnaces, Heaters, Fireplaces & Air Conditioning 16 09-06-2014 09:58 PM
New AC, Heat Pump or Heat strip? firedog 1990 - 1993 Excella 3 01-22-2010 04:23 PM
heat pump & furnace problem al66pine Furnaces, Heaters, Fireplaces & Air Conditioning 0 10-07-2009 02:04 AM
