Old 05-13-2010, 03:13 PM   #1
JJC
1995 30' Limited
Coniston , Ontario
Heat Pump
This winter (a cold one) I used my heat pump often. One morning I woke up to water all over the place and the fan was spewing water. The pan benith the AC was full of water . . . any thoughts. Jj
JJC is offline   Reply With Quote
Old 05-13-2010, 04:02 PM   #2
jcanavera's Avatar
2004 30' Classic Slideout
Fenton , Missouri
Images: 143
Sounds like the drain froze. When in a heat pump mode, the exterior coils can form ice. Typically the unit after running a certain amount of time, reverses cycles (without the fan running) which causes the outside coils to get warm. This causes the ice on the coils to melt. If it's cold enough that water might freeze up in the drain tube and the pan might fill.
While I haven't had the water issue, I have had the outside coils pick up so much ice, that the defrost cycle can't melt it all. What subsequently happened was a total ice up and we came back to the trailer only to find the temps inside to be pretty cool. This was in 100 humidity with the temps in the low 40's.
Jack
Jack Canavera
STL Mo.
AIR #56
Using the heat pump/heat strip instead of furnace. crazylev On The Road... 38 10-28-2016 07:58 PM
New AC, Heat Pump or Heat strip? firedog 1990 - 1993 Excella 3 01-22-2010 04:23 PM
AC and Heat pump not working BigPlay 2005 and newer - Bambi all models 4 01-19-2010 07:47 AM
Heat Pump? gaylejoe Furnaces, Heaters, Fireplaces & Air Conditioning 17 12-25-2009 11:44 AM
should i get the a/c with the heat pump?? evelitalian Furnaces, Heaters, Fireplaces & Air Conditioning 37 04-22-2008 06:17 PM
