Old 12-23-2009, 08:59 PM   #1
gaylejoe's Avatar
2007 25' Safari FB SE
St. Hedwig , Texas
Heat Pump?
Sometimes we hear two different motors running when using the heat pump. The fan will shut off and we can still hear another motor running. Is this normal? This past weekend we used it with outside temps in the upper 20's and if it froze up we were not aware of it. This our first heat pump and we are just trying to get use to it.
gaylejoe is offline   Reply With Quote
Old 12-23-2009, 09:31 PM   #2
jcanavera's Avatar
2004 30' Classic Slideout
Fenton , Missouri
Images: 143
The heat pump function has a fixed time limit in which it runs. Once it hits that time limit, the blower shuts down and the heat cycle reverses itself. What you hear is the compressor running. This causes the outside coil to heat up and melt any ice that may have formed on it. When you are in heat pump mode that outside coil gets cold and the inside one gets hot. When in air conditioning mode it's completely reversed.
First time you hear this, you think something has failed on the unit. Once the defrost cycle has ended, the fan will kick back on and the system will go back to heat mode.
Jack
Jack Canavera
STL Mo.
AIR #56
Old 12-24-2009, 07:35 AM   #3
Wingeezer's Avatar
2005 30' Classic
Burlington , Ontario
Slightly off topic, but we too are new to having a heat pump in our trailer.
I am wondering what, if anything, is the advantage when compared to just using one of those small ceramic cube heaters when on shore power?
We did use the heat pump for the first time on a trip south last winter, and it did work, but not great, and to my mind no better (maybe worse) than the little elec heater we have kept from our last trailer.
Seems to me to be little point in wearing out my AC compressor to run the heat pump compared to a $25 elec heater, so my preference so far is not to use it and just carry on using our little elec heater on cooler night.
Am I missing something? I wouldn't think the heat pump is more efficient, but maybe?
Brian
Brian & Connie Mitchell
2005 Classic 30'
Hensley Arrow / Centramatics
Old 12-24-2009, 09:04 AM   #4
moosetags's Avatar
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach , Florida
We have used our heat pump extensively (500+ nights of camping) and have found it meets our needs in most cool to cold circumstances. The first time that we used the heat pump in below freezing weather, it made strange alternate fan noises as jcanavera describes. We thought we had broken the darn thing. Since then, we use the heat pump in most cool weather circumstances, but we go to the gas furnace when the outside temperature drops below freezing.
We feel that the heat pump works very well and use it often. I don't believe that using the heat pump will at all shorten the life of the unit. On the contrary, not using the unit at all for long periods of time may cause seals to dry out and become prone to premature failure.
Brian
SuEllyn & Brian McCabe
Old 12-24-2009, 09:22 AM   #5
CLOUDSPLITTER "Tahawas"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Thumbs up
We too have used it extensively in above freezing temps. Works so well the Polinis has stayed in the closet.
Brian hit the rivit squarely, non-use is one of the main causes for AC/heat pump failure.
PFC
but I’m the Husband, so we went to Cleveland. 😂
RLC
Step aside Starbucks, this is a job for alcohol.
Old 12-24-2009, 10:04 AM   #6
2dabeach's Avatar
North/East , New Jersey
Brian
Brian....The main advantage of using the heat pump over a plug in electric heater is if your paying the electric bill. A typical plug in electric heater rated at 1,500 watts (12.5 amp) will provide you with 5,118 BTu of heat into your trailer. Heat pumps use the reverse refrigeration process and are able to get more output for the same amount of electric being consumed. A typical heat pump rated at 1,370 watts (11.4 amps) will provide you with 11,600 BTu/hour of heat into your trailer. That gives you 2.5 times more heat for the same amount of electric consumed. The only problem with a heat pump is that it loses it's efficiency as the outside temperature drops below 40F. Many of the units will shut down as the temperatures drop below 35F-40F and switch over to your propane furnace.
2007 Safari 25' FBSE LS
2006 GMC Sierra 2500HD Crew Cab 4WD Duramax
2dabeach is offline   Reply With Quote
Old 12-24-2009, 11:24 AM   #7
Wingeezer's Avatar
2005 30' Classic
Thanks for the feedback on advantages of using the heat pump! Appreciated!
Brian
2005 Classic 30'
Old 12-24-2009, 11:43 AM   #8
Naysayer
Boondocker's Avatar
1968 24' Tradewind
Louisville , earth
Send a message via Yahoo to Boondocker
I have a heat strip on the new Carrier low profile, I don't think it works the same way as described here. It is a sperate piece that bolts into the ducting of the AC. It has a copper tube that gets hot. I didn't know you could get a true heat pump option. Live and learn I guess.
Rodney
Visit my photography page
and the
Favorite camp grounds project map
My Blog
(The artist formerly known as General Disarray)
Boondocker is offline   Reply With Quote
Old 12-24-2009, 11:55 AM   #9
Wingeezer's Avatar
2005 30' Classic
Out last trailer had the heat strip setup, the AS has the true heat pump.
I was familiar with the operating principles involved in both, but didn't realize the magnitude of the efficiency comparison.
I suppose it must vary quite a bit though, depending on the outside temp?
Brian.
2005 Classic 30'
Old 12-24-2009, 12:03 PM   #10
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
The heat strip is a nice option. I have one on my Carrier LP. It worked very well when I was in Fort Collins this October. Unlike a heat pump, it works equally as well regardless of the outside temperature.
Richard
Old 12-24-2009, 12:56 PM   #11
vswingfield's Avatar
1983 34' Excella
1967 24' Tradewind
Little Rock , Arkansas
Images: 32
The behavior discussed in the earlier posts is from owners of newer Airstreams. From their descriptions, my guess is that these are ducted systems with a wall thermostat, not self-contained (Freeblow in Carrier speak) rooftop units.
I installed a Carrier 15,000 heat pump model at the end of March, 2008 (http://www.airforums.com/forums/f427...ead-40795.html), so this is my second winter to use the heat pump. Mine is a self-contained unit like yours, I'm not sure when the switch to the ducted models took place in Airstreams, but it was after 1983. The fan runs full-time like the AC, so the behavior gaylejoe described never comes up. The fan noise covers the defrosting cycle that Jack discussed in his reply. The self-contained heat pump models also have a heat strip (just like yours), so they switch to the heat strip when the temperatures drop low enough for the heat pump to lose efficiency. The ducted models switch to the Airstream's furnace.
I find that the heat pump works very well here in central Arkansas. It rarely gets cold enough to switch to the heat strip, but when that happens it does so just fine. I only had the furnace on a couple of times last winter, and only for brief periods of time. So far this winter, just a test firing to insure that everything was Ok.
Given all that, I'm sure that you are going to be happy with yours. I use an electric oil radiator as my first line of defense against the cold and go to the heat pump when it can't keep up. That's what I am using right now. It's 55 outside and raining (we set a new record for the rainiest year in Arkansas history last night and it has been raining hard ever since) and the inside temp has crept up to nearly 75 with just the oil radiator. I really need to adjust the thermostat on the oil radiator a little, but I think I'll take a shower first. It is totally silent so I do use it when it will do the job.
Vaughan
Old 12-24-2009, 01:18 PM   #12
Naysayer
Boondocker's Avatar
1968 24' Tradewind
Louisville , earth
Lost as last years easter egg
Now I am completely lost. Are you saying the new Carrier low profile units have heat pump capacity and a heat strip that kicks in a low temps? That would be pretty cool. Or does my new unit only have a heat strip?
Rodney
and the
My Blog
Old 12-24-2009, 02:01 PM   #13
1983 34' Excella
1967 24' Tradewind
Images: 32
Hi Rodney,
Unfortunately (?..at least for definitive answers), both kinds are available. Unless you specifically bought a heat pump model, you probably have the heat strip only. Given that, you would have paid less too, so there would be some offset of heating savings in the purchase price I guess. The options are the same whether you get a low profile or, like me, the standard one. You are right, the heat pump units have the heat strip that kicks in at low temps and it is pretty cool, or would that be hot!? It does work nicely.
I went with the standard for a couple of reasons, including a few more CFM from the fan. I also decided that a 34' trailer could handle the visual impact of the standard unit, but i'll have to admit, the low profile models are good looking. More detailed information is available at Carrier Product Line. Unfortunately, you have to open and plow through a punch of pdf files rather than use a "compare" feature like some websites.
Vaughan
Old 12-24-2009, 09:05 PM   #14
Pahaska's Avatar
2014 Interstate Ext. Coach
Hays County , Texas
In central Texas, I use a ceramic heater when we are in the forward part of the trailer since we usually have the TV on and tht heater is quieter than the heat pump. When we go to bed, I switch to the heat pump since the heat reaches to the bedroom a lot better.
Also, with the heat pump on, the system will switch to furnace if the outside temperature goes too low. We have had that happen only a few times since our lows are usually above that point.
In the Dometic systems, the fan goes off during the defrost cycle. Apparently that doesn't happen with the Carrier according to previous posts. That would tell me that the Carrier is going to blow a lot of cold air during defrost.
John W. Irwin
WBCCI #9632
Using the heat pump/heat strip instead of furnace. crazylev On The Road... 38 10-28-2016 07:58 PM
Carrier 13.5 heat pump crispyboy Furnaces, Heaters, Fireplaces & Air Conditioning 10 02-22-2009 03:37 PM
Heat Pump Question jeff4506 Furnaces, Heaters, Fireplaces & Air Conditioning 6 12-24-2008 04:38 PM
heat pump or a/c unit twiggy137 Furnaces, Heaters, Fireplaces & Air Conditioning 5 06-04-2008 08:53 PM
should i get the a/c with the heat pump?? evelitalian Furnaces, Heaters, Fireplaces & Air Conditioning 37 04-22-2008 06:17 PM
