Old 12-25-2009, 08:58 AM   #15
jcanavera's Avatar
2004 30' Classic Slideout
Fenton , Missouri
Images: 143
Problem with the heat strips is that there is no thermostat control. You get cold, you turn it on. It gets too warm, you turn it off.
There is one other issue with the heat pump. If that defrost cycle isn't long enough, the unit freezes up. I had that happen in Branson one October. It rained all day, temps were in the upper 30's. With the outside humidity extremely high the cold outside coils condensed ice on them. The unit did it's defrost cycle but due to the humidity, the ice didn't completely thaw. Well this was going on all day and by the time we got back to the trailer that evening I found the trailer inside was cold with the heat pump blowing luke warm air. I pointed the flash light on the outside of the trailer and found the outside coils encrusted in a block of ice. The next morning I went out and took this picture. You can see the coils still hadn't defrosted. I still use the heat pump, I just exercise a little restraint when the temps reach 40 and it's extremely humid outside.
Jack Canavera
STL Mo.
AIR #56
Old 12-25-2009, 09:49 AM   #16
blickcd's Avatar
Milford , Ohio
I also installed a Carrier AirV heat pump about year and a half ago. Part of the reason I got it was the fact that it would automatically switch on the heat strip instead of constantly defrosting when the temperature outside got too cold. This is the standard profile unit and it looks okay on a 31' trailer.
Something I heard but don't know for a fact is that Carrier stopped making these. Maybe they didn't sell enough to be profitable. A real shame if that is true.
Christopher
blickcd is offline   Reply With Quote
Old 12-25-2009, 09:50 AM   #17
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
Jack - The Carrier Unit Heat Strip does have a setting for temperature. It's a hot<->cold knob that you need to mess with to find your comfort zone. The fan does not stop when the strip powers off.
Richard
Old 12-25-2009, 11:44 AM   #18
jcanavera's Avatar
Fenton , Missouri
Images: 143
Glad that Carrier addressed that. With Dometic there was no option like that.
Jack Canavera
STL Mo.
AIR #56
Using the heat pump/heat strip instead of furnace. crazylev On The Road... 38 10-28-2016 07:58 PM
Carrier 13.5 heat pump crispyboy Furnaces, Heaters, Fireplaces & Air Conditioning 10 02-22-2009 03:37 PM
Heat Pump Question jeff4506 Furnaces, Heaters, Fireplaces & Air Conditioning 6 12-24-2008 04:38 PM
heat pump or a/c unit twiggy137 Furnaces, Heaters, Fireplaces & Air Conditioning 5 06-04-2008 08:53 PM
should i get the a/c with the heat pump?? evelitalian Furnaces, Heaters, Fireplaces & Air Conditioning 37 04-22-2008 06:17 PM
