Old 10-09-2008, 10:52 AM   #1
cadoc
1972 31' Sovereign
Lake Isabella , California
Images: 8
Question Heat Duct Assembly Mystery Hole Under Tub
In the process of lighting the NT30 in my 31 ft Sovereign (after 12 years of non-operation) I pulled the heat duct covers for a little vac and found a 3" hole about 12" inside the rear heat duct. It is mis-aliegned but clearly has an aluminum hose going somewhere. The manual shows and says nothing about this little goodie.
I imagine it may help keep water lines inside the rear access door from freezing. If it is OEM then I will assign more importance to getting it lined up properly.
Has anyone ever seen one of these?
The furnace lite like a champ.
Doc
cadoc is offline   Reply With Quote
Old 10-09-2008, 10:56 AM   #2
cadoc
1972 31' Sovereign
Images: 8
Solved
I found the right thread, it's to the black water tank.
heat ducts, 31', furnace
Using the heat pump/heat strip instead of furnace. crazylev On The Road... 38 10-28-2016 07:58 PM
where does this duct go?? wannaroam Furnaces, Heaters, Fireplaces & Air Conditioning 12 10-28-2013 07:45 AM
Questioning a Duct Stone Ridge Furnaces, Heaters, Fireplaces & Air Conditioning 3 02-09-2008 08:20 PM
Duct to nowhere walter1 Furnaces, Heaters, Fireplaces & Air Conditioning 5 12-17-2004 07:16 PM
why does the heat duct connect to the black water tank jgouras Furnaces, Heaters, Fireplaces & Air Conditioning 5 08-27-2004 02:28 PM
