Old 03-08-2019, 05:35 AM   #1
2019 30' Classic
Crested Butte , Colorado
Heat/Cool...no auto setting?
The weather has been pretty odd down in Florida, 30s overnight to 90s during the days. The last couple of days of colder weather has meant we have to heat the trailer at night but the trailer sees 80s internally during the day. My 2012 25' EB had less complex electronics but its thermostat had an Auto setting. Set the temperature to 70 degrees and the heat pump switches back and forth from heat to A/C depending on what the trailer requires to hold temp. Who woulda thought?
Sometimes more complicated is not better. Certainly, the dual units heat or cool the trailer down quickly but where the heck is the Auto setting in these fancy electronics?
2019 30' Classic RB pulled by 2013 F-150 Eco-Boost Platinum with Max Tow Package
Froglips is offline   Reply With Quote
Old 03-08-2019, 08:31 PM   #2
BigSxyWhtGuy's Avatar
2018 30' Classic
Thousand Oaks , California
Is your question if it has an auto feature?
I have an 18 firefire controll panel. Mine has auto. Same place the other controls are
BigSxyWhtGuy is offline   Reply With Quote
Old 03-09-2019, 05:30 AM   #3
Well Preserved
overlander63's Avatar
1993 21' Sovereign
Colfax , North Carolina
I'm not where I can look at one of the C Zone controls right now, but a workaround would be to set one HP to heat, set to, say, 70, and the other one to cool, set to 75.
Old 03-10-2019, 01:50 AM   #4
2019 30' Classic
Yes, a work around is possible using the Alde system to heat and both ACs to cool. That isn't really my point.
Old 03-15-2019, 06:22 AM   #5
2019 30' Classic
The CZone and Firefly are not the same.
Optional heat setting Shelly Lynn Furnaces, Heaters, Fireplaces & Air Conditioning 1 01-29-2016 12:47 PM
Down the road with heat/cool on ? Focusfactor1 Furnaces, Heaters, Fireplaces & Air Conditioning 9 09-25-2012 08:35 AM
Dometic Duo-Therm "Cool Cat" heat pump/AC unit?? PA BAMBI II Furnaces, Heaters, Fireplaces & Air Conditioning 4 08-19-2010 08:52 PM
carrier v low cool vs high cool joewinfield Furnaces, Heaters, Fireplaces & Air Conditioning 2 06-06-2008 08:20 PM
Heat Pump blowing cool air? craftsman Furnaces, Heaters, Fireplaces & Air Conditioning 11 04-08-2008 06:01 PM
