Old 09-09-2016, 10:32 AM   #29
1980 31' Excella II
panama city beach , Florida
Local RV person here wants $1700 for a new roof A/C and labor for installation. Is this in the ballpark of your installation? The unit I have now that is not working, I think is the original Armstrong.
thestork
thestork is offline   Reply With Quote
Old 09-09-2016, 11:14 AM   #30
HowieE's Avatar
Princeton , New Jersey
Images: 12
A Premium AC can be bought for about $800.00 plus $40.00 for the drain kit. Its about a half hour to install the drain kit and an hour for 2 people, with knowledge, to install the unit. That is why they call them Stealers.
2004 Excursion 4x4
Old 09-18-2016, 01:14 PM   #31
carl2591's Avatar
2005 31' Classic
Garner, , North Carolina
plus they cut the coils out of the unit and take to local metal recycle place and get another 20 or so bucks for the old unit.
The unit is like $800 or so, depending on model and size and the remove, install is not all that. you need a good helper, some osb board cut in sections of like 2.5 ft x 3 ft some blankets to cover the metal up top. you can find a video on youtube with enough info to get you through it.
good luck
Carl, Raleigh NC
2-24-16 got a 2005 Classic 31D
TUG2.net check it out for good rental deals
2003 F-250 SD, CC, 7.3L PowerStroke
WBCCI#1691, Piedmont Airstream Club, Unit #161, Region #3
carl2591 is offline   Reply With Quote
Old 09-25-2016, 07:26 PM   #32
Pensacola , Florida
ac install
We have a 2001 Excella BTW. After reading this thread and others, I'm totally confused about which Brand to replace my original AC with...
My local repair guy suggested Atwood but after reading a thread about the Atwood unit not working with the original heat pump(not communicating)and their lack of customer service...... and Atwood being bout out by Dometic) not so sure...
Also, with all appliances these days being made cheaper and cheaper is there no good option anymore?
should I just repair the Dometic?
thanks, Billy
Silverhorse9 is offline   Reply With Quote
Old 09-25-2016, 08:26 PM   #33
Cperreira's Avatar
1976 23' Safari
Oakdale , California
What if A/S never had A/C?
Hi Everyone,
First timer picking up our very first '76 Safari 23' A/S tomorrow. The trailer doesn't come with an A/C unit at all. Do you think this will be an even more complicated job to install?
Thanks for the help,
Chris
Cperreira is offline   Reply With Quote
Old 09-25-2016, 08:32 PM   #34
Vintage Kin
slowmover's Avatar
Fort Worth , Texas
Originally Posted by WayneG View Post
If you dont have another way to get a AC unit on your roof, check out my method:
http://theouterlimits.ws/projects/ai..._ac/index.html
Out the window over the garage on 2x10 planks. Just dont ask me how I got the old one down.
I used two 16' 10x2 pressure treat to come up from the tailgate of my truck on the Silver Streak ("better" roof than an AS, perhaps, I never worry about walking on it except when slippery; roof penetration is supported by aluminum rectangle tubing. I closed off with alum tape).
Cut boards up later to use for parking and leveling. Would have bought 12" had I thought about it a little more for the secondary use.
A neighbor was good enough to help guide and push as I pulled a rope fixed around the shipping carton. Have done (4) AC replacements the last five years on (3) trailers.
Another method is two men on two side by side ladders. I'm just too old to horse these 105# units up by myself any more.
Hensley Arrow. 9-cpm solo, 15-cpm towing
Old 09-26-2016, 05:55 AM   #35
HowieE's Avatar
Images: 12
thanks, Billy
You mention repair as an option. That depends on what is wrong with the unit. If is not the compressor or a leak repair is a possibility.
2004 Excursion 4x4
Old 09-26-2016, 06:47 AM   #36
1972 27' Overlander
Denver , North Carolina
If you have an Armstrong you are in luck. Those units are commercial grade and rebuildable.
Lucky Dave, Denver NC
mccrosti is offline   Reply With Quote
Old 09-26-2016, 06:56 AM   #37
1988 25' Excella
1987 32' Excella
Knoxville , Tennessee
$1300 installed on site last year in Dade City, Fl. Took the Toy Doctor about 2 hours max and he hooked up the drain lines and made sure the pan did not leak.
Build your own rock guard...you can do it! Becky B. Windows & Screens 48 11-30-2017 05:57 AM
Roof Mounted Antenna: Does it have a hand crank somewhere? chaseav 2011 - 2015 International 10 07-06-2016 05:24 AM
Own your own scale? Ag&Au Jacks, Stabilizers, Lifting and Leveling 8 01-26-2014 02:52 PM
Any of you Minuet owners done your own brakes? Van All Argosy Trailers 7 06-02-2010 06:54 AM
Playing music from your computer through the mounted speakers ARMYOFME Computers, Internet & Satellite 12 04-28-2009 11:59 AM
