02-04-2015, 10:35 AM
1965 24' Tradewind
Henderson
, Nevada
Has anyone used this Olympian Wave Heater yet ?
Hi all , My 65 Tradewind heater is toast and I was looking at this Wave 3 heater as an alternative . I live in the desert so the massive loud old heater is over kill anyways. Also if you have used this heater , does it need the regulator that comes with it or does our main regulator cover this flow ?
OLYMPIAN WAVE CATALYTIC SAFETY HEATERSThe ideal heaters for either your primary or secondary heating source, Olympian Wave Catalytic Heaters operate on low pressure L/P gas and can be wall mounted or used as portables. The built-in automatic Piezo electric spark starter will last for 20,000 starts and is self-generating. No electrical connections or battery drain. No flame, no flue or chimney, no fan or blower, no noise; just dependable, penetrating soft infrared heat.
02-04-2015, 10:46 AM
Powder Springs
, Georgia
We have the larger version of this heater. Your main regulator is just fine. The regulator included with the heater is for connecting it directly to a propane bottle.
~Lynnetta
1997 25' Safari
1973 25' Tradewind
Greenville
, South Carolina
Yes, I have it in my Globetrotter. Works great and it has an oxygen sensor which will cut off heater if there isn't enough.
02-04-2015, 10:49 AM
We have one in our 31'. Works well as a supplemental heat source.
William C. Swinney
02-04-2015, 11:00 AM
1965 24' Tradewind
Henderson
, Nevada
Great to to hear and thanks for the heads up on the regulator Did any of you mount it with kit ? If so how's that working out ?
THANKS !!!
02-04-2015, 11:56 AM
Free Range Human
2012 25' FB Flying Cloud
Haines
, Oregon
I suspect a Wave 6 would give you better performance. I am thinking about installing one in my AS, and a Wave 3 in my truck camper. Have a CO monitor, and be aware that there is condensation from the catalytic heaters. Keep a vent open.
02-04-2015, 12:00 PM
THANKS !!!
Ours is plumbed into the LPG system and utilizes the factory main line and regulator.
William C. Swinney
02-05-2015, 11:40 AM
1966 20' Globetrotter
2008 23' International
Cedar Falls
, Iowa
I installed one in my '66 Globetrotter after removing the original furnace. Works great although I sometimes wish I had purchased the Wave 6 since it doesn't provide enough heat once the temps fall below 40.
Hahnstead Airstream Park
02-05-2015, 11:41 AM
Lynn
Beaverton
, Oregon
wave heater
We have the wave 6 in our 25' AS and love it! Ideal size.
Lynn
02-05-2015, 11:45 AM
Purchased a wave 8 to use in our 2001 31 ft TT. I broke it in per instructions that came with it. Did not care for it because of the fumes it gives off. When lighting it would set off the smoke alarm. Plan on replacing it with a ventless convection propane heater so as to heat the air instead of objects like radiant heaters do.
02-05-2015, 12:06 PM
Tom T
Orange
I'm looking at putting their larger Wave 6 model in our 1960 Avion T20, since a PO removed the wall heater, but the LP & floor/roof vents are still intact (so I don't need to worry about cracking a window.
I talked to another 1963 Avion T20 owner up in IL who had the Wave 6 model & it worked fine for him & his wife Spring thru Fall (not sure about winter up north).
However, I've had some folks say that the heat from them when mounted into the cabinet can damage the wood/finish over time, just as the original wall heaters & gas lanterns did. So something to be aware of.
The Wave 6 width fits into our existing wall heater space, but I'd do a Wave 8 for more heat if it fit without cutting cabinetry. I can't find a space to put in an Atwood forced-air heater, so this seems like the best solution.
I think you need at least a Wave 6 if not 8 model for your TT - even in the AZ desert!
Also, Vintage Trailer Supply (& maybe others) sell a metal surround finishing kit for mounting the Wave 3, 6 & 8 into your cabinetry cleanly, which is worth getting to finish it off nice!
Price check for the Wave heaters, cuz they vary widely!
Stay Warm!
Tom
Tom T
Orange CA
1960 Avion T20, #2 made, Hensley Cub, TV tbd- looking for 08-22 Cayenne S, EH, etc
1988 VW Vanagon Westfalia CamperGL (Orig Owner) + 1970 Eriba Puck
02-05-2015, 12:47 PM
Happy Camper
2018 30' Classic
Flat Rock
, North Carolina
Installed the Wave 8 with optional legs in our 31' and it works great as a portable heater. Can direct it toward rear bedroom or front lounge from galley. Since it is a radiant heater, it does take a while to warm up the contents but once everything is warm, it is quiet and efficient heat.
02-05-2015, 03:44 PM
2013 Interstate Coach
Opelika
, Alabama
I have the Wave 3 in my 17' 1965 Caravel and plumbed it directly to the lpg system. Hung it by the door but didn't have too many other options. Make sure you buy the cover for it. Thinking of adding a 12v fan higher in the ceiling to help with the circulation. It's a gradual heat so I have to start it early to get R2 toasty.
Mike Hamilton
WBCCI # 2766
2013 Airstream Interstate (Darth Vader)
1965 17' Caravel (R2D2)
02-05-2015, 07:45 PM
We run a Wave 6 in our 31' with good results.
William C. Swinney
02-05-2015, 09:46 PM
Western
, Massachusetts
The moisture problems referred to in earlier posts don't seem to be a problem in your back yard. We ran the same heater in our 26' Overlander in Lake Havasu City and Death Valley Junction this week. My notes say that it was 34 degrees outside at 2900 feet. We ran one heater with plenty of ventilation and we kept the trailer at 63 degrees. Note that we had Prodex in all windows.
If you need it warmer or need more heat due to lack of window insulation, consider the Wave 6 or -- like us -- 2 Wave 3's. We like the ability to warm the rear of the coach in the morning and run the main one up forward overnight.
I mount them on hinges with a flex line. See my Caravel thread for details.
03-02-2015, 11:05 AM
1968 30' Sovereign
Seattle
Hi Kevin245, I have a '68 Sovereign 30 and wonder where you installed the Wave 6 in your rig?
03-02-2015, 12:19 PM
We mounted ours on the left cabinet bulkhead just inside the entrance door.
William C. Swinney
03-02-2015, 01:35 PM
1965 17' Caravel
1965 17' Caravel
Memphis
, Tennessee
Timely posts here, as I just installed a Wave 6 in our 65 Caravel. It fits pretty well in the space originally home to the old Hydroflame. I had to cut .5" off the top and bottom of the cabinet opening and add a 2" piece of wood to the left side to fill some space. I mounted using the recess mounting kit. The original post here shows the Wave 3. The Wave 3 cannot be mounted with a recess kit, only the 6 or 8 can. The Wave 6 mounted, using the recess kit, looks and works very much like the original hydroflame. I am happy with it and it seems to heat the camper well. Will try it out more as the temps are expected to fall here again soon.
1965 Airstream Caravel, 2003 Ford F150 SuperCrew, 2003 Miata Special Edition, 1993 Miata Black & Tan
