Old 08-17-2011, 01:06 PM   #1
1978 Argosy 27
Lacey , Washington
Images: 8
Has Anyone had this problem?
I have earwigs in the A/C compartment. It appears that the little critters got into the H2O drain tube behind the wheel and worked their way up the tube to the A/C. Now I need to find a way to make sure they are out of the A/C and my trailer and then keep them out. Any ideas out there?
jjustice
jjustice is offline   Reply With Quote
Old 08-17-2011, 01:15 PM   #2
Steve & Susan's Avatar
2005 28' International CCD
Willoughby , Ohio
Blow out the drain tube with some compressed air? from the top down, maybe a shot of raid into the bottom of the tube (I wouldn't cover the tube end with screening as it may clog), those are the first two things that come to mind...
Steve & Susan
WBCCI# 03876
AIR# 6511
2005 28' CCD, 2011 Sierra 5.3L, Equal-I-Zer
Empty Nesters - spending our money on OURSELVES for a change!
Steve & Susan is offline   Reply With Quote
Old 08-17-2011, 01:57 PM   #3
Registered User
1998 34' Excella 1000
1995 36' Classic 36
Spencerville , Maryland
Images: 14
I would call Kirk and ask for his advice in dealing with those things!
GREENovaters is offline   Reply With Quote
Old 08-17-2011, 03:06 PM   #4
1978 Argosy 27
Lacey , Washington
Images: 8
earwigs cont.
Thanks but who is Kirk?
Old 08-17-2011, 03:23 PM   #5
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
The Captain....
PFC
"Tahawus"
RLC
Its a crooked piece of time that we live in.
John Prine
Old 08-18-2011, 05:58 AM   #6
Willoughby , Ohio
Originally Posted by ROBERT CROSS View Post
The Captain....
Wasn't it Chekov and Captain Terrell who got those little beasties put in their ears by KAHN?
Steve & Susan
WBCCI# 03876
AIR# 6511
Old 08-18-2011, 06:26 AM   #7
Why does it not surprise that Streamer's are closet trekkies....
PFC
"Tahawus"
RLC
John Prine
Old 09-02-2011, 10:15 AM   #8
1972 25' Tradewind
Madison , Wisconsin
jjustice
Any place that is dark and holds moisture is home to earwigs. I am always amazed how many get into private water supply wells that are not equipped with vermin proof caps. Who knows maye a campground or two still has one of those old style well caps
The advice about clearing your drain tube is a good idea. Turn the AC power off , then pull down your AC lower unit and clean it out, may as well do the filters while you're at it. You can check the duct but probably will not fin anything there. Be sure to check for condensate leaks. Earwigs do not stay in areas that are only occasionally moist, something may be holding moisture.
Smokin Camel is offline   Reply With Quote
Potential Problem? Pictures included palmtreegirl 1990 - 1993 Excella 51 08-12-2013 10:50 PM
Interesting Tongue Jack electrical problem Wingeezer Jacks, Stabilizers, Lifting and Leveling 15 10-12-2012 10:08 PM
Cooling problem on gas Pahaska Refrigerators 38 08-22-2011 05:18 PM
Barker Super Jack Problem Luckyducks Jacks, Stabilizers, Lifting and Leveling 1 03-20-2011 08:49 AM
