Old 04-15-2019, 04:28 AM   #1
Got a Penguin 2 AC unit. Which interior box to buy?
Got a good deal on a Penguin 2 AC unit. Model number is 640315CXX1C0. New, but a scratch n dent deal.
Did not come with the interior air distribution box.
I have researched, and feel increasingly confused on what I need to install.
Ducted or non ducted?
Manual or electronic controls?
Can I add heat strips?
Advice and knowledge please!
Old 06-12-2019, 01:51 AM   #2
1976 27' Overlander
Milwaukie , Oregon
Did you ever get an answer on this?
JoleneAS is offline   Reply With Quote
Old 06-12-2019, 07:00 AM   #3
A W Warn's Avatar
2000 25' Safari
1999 34' Excella
Davidson County , North Carolina
Does your RV have ducts in the ceiling. I doubt your 345 is ducted, so you need the non ducted ADB.
Do you want to control the unit using a wall thermostat or thermostat that is built into the bottom of the AC unit?
If you want to use a wall thermostat, then you will need to also order the Comfort Control Center thermostat and the ADB without controls and thermostat built in.
If you want the controls on the bottom of the AC unit order the ADB with the controls built into it.
Yes, you can add heat strips. Either ADB will work.
Alan
2014 Silverado 1500 Crew Cab 5.3L maximum trailering package
Old 06-12-2019, 07:24 AM   #4
A W Warn's Avatar
2000 25' Safari
1999 34' Excella
I forgot to mention:
1. If you add the wall mounted CCC thermostat you will need to run a Dometic data cable between the thermostat and the AC unit.
2. You may (I'm not sure) need an additional control module to bolt onto the AC unit.
3. You will need a 12v power supply at the AC roof opening.
4. You can control the furnace with the CCC thermostat, but you will have to extend the two blue thermostat wires to the AC roof opening.
Alan
Penguin 2 with HP...which ADB will work best? mschneid General Repair Forum 3 01-24-2017 10:40 PM
Which A/C unit do I buy? Airboutique Furnaces, Heaters, Fireplaces & Air Conditioning 0 07-28-2016 11:11 AM
Penguin I to Penguin II drain pan? HiJoeSilver General Repair Forum 1 05-25-2015 04:51 AM
I have 3 boxes of assorted parts from my airstream 59 Tradewind, I would like to sell by the box for 300.00 per box or best offer per box 59as Airstream Classifieds 0 09-19-2014 11:01 AM
Need Dometic Duo Therm Penguin air distribution box gloran Land Yacht/Legacy Motorhomes 1 01-20-2007 11:00 AM
