Old 10-11-2010, 02:09 PM   #1
1978 Argosy 27
Lacey , Washington
Images: 8
Going to Replace the ol Suburban Furnace
We are planning on going south (from WA ST) this winter and the old Suburban furnace in our '78 Argosy works but not very well and it is 32 yrs old. I am planning on replacing it but would like to get some options as to a replacement furnace - catalytic? newer Suburban or??? Any ideas/experiences are helpful. thnks jjustice
jjustice is offline   Reply With Quote
Old 10-11-2010, 02:15 PM   #2
Splitrock's Avatar
Sioux Falls , South Dakota
I ordered a new Suburban. UPS just brought it.
Old 10-13-2010, 08:31 AM   #3
Silverhobby's Avatar
1967 26' Overlander
1968 30' Sovereign
BULLS GAP , Tennessee
jjustice, Replacing your old furnace with a new Suburban should be an almost easy changeout. Suburban for Suburban is a good choice.
//------AIR # 7303------\\
WBCCI 17109
visit my restoration blog at:
Old 10-13-2010, 11:42 AM   #4
Full Timers/Diesel power.
Mike Leary's Avatar
Cactus Hug , Arizona
Images: 11
Our first Suburban lasted 20 years, no problem other than replacing the iginitor board with a quality Dinosaur product. We replaced the furnace in 2001. Only used it in the mornings since we have oil-filled radiators fore and aft. We never use it during our winters in Arizona. That being said, we have replaced the heater motor four times, the ignitor once, gas valve twice, electrode twice, limit switch three times. Needless to say, we are not pleased with the product. :
Dinosaur Electronics Home. High quality circuit boards for RV appliances.
"A settled wisdom, plus the itch to be elsewhere"
Mike Leary is offline   Reply With Quote
Old 10-13-2010, 12:22 PM   #5
Ottawa , ON
Other than that, it's been OK, though?
Old 10-13-2010, 09:11 PM   #6
Mike Leary's Avatar
Images: 11
My main regret is I own no stock in Suburban!
Old 10-13-2010, 09:49 PM   #7
Roadrunner's Avatar
1978 29' Ambassador
1974 25' Tradewind
1974 27' Overlander
Indiana , Pennsylvania
Ours is coming Friday...tis the season!
Roadrunner is offline   Reply With Quote
Old 10-13-2010, 10:08 PM   #8
Mike Leary's Avatar
Images: 11
You can replace the electrode yourself when it goes south, be sure to get the gaskets, also. A good hand can also replace the limit switch if there's enough wire free. Otherwise, the furnace comes out. Remember, no need to remove the enclosure, blow and vacuum the hoses when the furnace comes out, which, it will, if my bad luck is any indication.
Old 10-13-2010, 10:26 PM   #9
RichHog's Avatar
1972 25' Tradewind
Houston , Texas
Put a Sub NT30 SP in my 72 trade wind last Feb. There's a thread out there of what I did, used 2x2s to build a frame under it and wrapped with silver tape to seal. Had to use tin snips to cut around the old furnace cover as the gas line comes in on the right side.
The Nt30SP is smaller that the original 24 but puts out more heat and is pretty quiet.
Believe
Palamino Rv had the lowest price around on furnaces.
RichHog is offline   Reply With Quote
Old 10-14-2010, 07:55 PM   #10
Silver Mist
LI Pets's Avatar
1977 31' Sovereign
Riverhead , New York
Just installed one over the weekend, it was not 100% plug and play, there were a few tweaks.
But it's nice
'77 Sovereign Intl 31' CB
Old 11-08-2010, 04:27 AM   #11
frankfarmer's Avatar
1992 34' Limited
Snead , Alabama
Guess my time to replace furnace
Original 93 SuburAN fan motor SQUEALLING like crazy, are new suburbans good furnaces??? any idea of cost? Plan to call service center to quote & install, I'm no wiz with gas heaters.
frankfarmer is offline   Reply With Quote
Old 11-08-2010, 05:34 AM   #12
Silver Mist
LI Pets's Avatar
1977 31' Sovereign
Just did mine, sp30 about $500.
very quite, throws heat out better than the old one
Old 11-08-2010, 05:16 PM   #13
1992 34' Limited
Snead , Alabama
How major a job is it to replace suburban furnace????
Service guy coming to give me a quote, if not a bear I may buy one direct & do it myself. ?????
1993 34 ft. classic, full time live aboard, first winter.
Thanks for any advise.
Also I plan to replace old Attwood water heater, it smokes, real old, do not trust it. Service guy to look at it also & give me a quote to replace it with suburban unit.
Old 11-08-2010, 05:24 PM   #14
x
XXXX , XXXX
Frankfarmer replacing a furnace in a 93 should be a straight forward replacement job. Simply remove the old one and install a direct replacement. Ducting and gas lines should match up directly without any modifications. IMHO I would replace the water heater with an Atwood model. Again it should be an easy replacement without any mods. If you use a suburban it will bw a different size and require modifications to the shell to accept the different size unit.
wasagachris is offline   Reply With Quote
suburban furnace gettysburg Furnaces, Heaters, Fireplaces & Air Conditioning 11 01-02-2009 07:38 PM
suburban NT24SP furnace problem repair or replace modnodd Furnaces, Heaters, Fireplaces & Air Conditioning 2 12-19-2008 11:21 PM
Suburban furnace pjude General Motorhome Topics 4 10-16-2007 09:00 AM
Suburban furnace 34 NT pjude Classic Motorhomes 3 07-29-2007 11:06 AM
Suburban Furnace tmeagle1 Furnaces, Heaters, Fireplaces & Air Conditioning 25 02-20-2004 08:18 AM
