Old 11-22-2009, 05:19 AM   #1
Lothlorian's Avatar
Loganville , Georgia
Giving old furnace away... Do you want it?
I have a 30,000 BTU Suburban furnace I pulled from my overlander. If you pick it up from my house you can have it. Otherwise it is going to be discarded. If it was ever used it was not used very much. Looks like new. It is missing the cap that covers the pilot light. I could not get it to light and decided to buy a new one. I put the new furnce in the old case of the old furnace. It does not have a case.
When I pulled the old furnace I noticed that mud dobbers had plugged up the air intake and the exhause port. There also looks like there was a wrens nest in it. The fan works.
Just e-mail me.
Brian
Brian & Adrienne
Lothlorian is offline   Reply With Quote
Old 11-22-2009, 06:43 AM   #2
MrsGlisten
1959 22' Caravanner
1963 24' Tradewind
Anderson , South Carolina
Yes, I would like to get it. I live 100 miles away in Anderson, SC. I will send you a PM.
MrsGlisten is offline   Reply With Quote
Old 11-22-2009, 10:41 AM   #3
Zeppelinium's Avatar
1975 31' Sovereign
1977 23' Safari
Palmer Lake , Colorado
I have two to give away.
Zep
Old 11-22-2009, 11:36 AM   #4
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
The fan on mine makes a lot of noise after it runs for a while. I could use one for parts. Mine is the infamous NT-22.
Richard
Old 11-22-2009, 01:12 PM   #5
1975 31' Sovereign
1977 23' Safari
Richard, I'll check the fan on the one that's really only good for parts. It's out at the Safari, so it'll be a couple days.
BTW, I did check for that overhead door guide to replace the one we cut when putting in your A/C. It's not similar enough to replace yours.
Zep
Old 11-22-2009, 01:21 PM   #6
2002 25' Safari
Dewey , Arizona
Images: 62
Zep
The search continues...
Richard
Old 11-22-2009, 05:40 PM   #7
Lothlorian's Avatar
My suburban furance is the orginal and it was in my 1973 Overlander. I do not think it was a nt 22. The fan worked really well. I am not a heating and air tech and the RV techs would not work on it because of its age. It is in great shape.
I am very happy with my new one. I bought mine and installed. It is really quiet and warms the airstream in minutes.
Brian
Brian & Adrienne
Old 11-22-2009, 05:48 PM   #8
silverleeper's Avatar
1967 22' Safari
1960 Caravel
Edmonds , Washington
Images: 8
I have a NT-22 that I'm dumping. The fan worked when I pulled it. Do you want it?
Lee
1973 F-250 4X4 390
1965 Chevy Suburban 454
AIR 6030
WBCCI 4258
TCT
silverleeper is offline   Reply With Quote
Old 11-22-2009, 08:33 PM   #9
2002 25' Safari
Dewey , Arizona
Images: 62
Lee,
Thanks, but I'll see what Zep has. Since I run into him a couple of times a year, there will be no shipping.
Richard
Old 12-23-2009, 01:36 PM   #10
69SafariDude
1969 23' Safari
Indianola , Washington
NT-22a fan wanted
Hello Silverleeper,
I live just across the water from you it looks like (I'm in Indianola). I need a fan for my NT-22a if you still have one.
David (mandonaut)
mandonaut is offline   Reply With Quote
Old 12-24-2009, 06:57 AM   #11
Jim & Mitzi's Avatar
1990 34' Excella
1990 29' Land Yacht
Americus , Also Valrico, Fl
furnace in Loganville, GA
I'm in Americus, GA Would be glad to have the furnace.....How far away is Loganville.....???? Happy Holidays
Jim & Mitzi is offline   Reply With Quote
Old 12-24-2009, 09:14 AM   #12
Lothlorian's Avatar
Loganville is a trip. I am 45 minutes from Athens Georgia of of hwy 78 . It is yours for the taking. I also have other bits and pieces I am trying to get rid of. I pulled all the orginal vents and put in new ones.
Brian & Adrienne
Old 12-25-2009, 07:58 AM   #13
1990 34' Excella
1990 29' Land Yacht
Merry Christmas
Good Morning, Have friends in Conyers Trying to contact them to see if they can come get it for me....Have a great day.....JC
Old 12-26-2009, 06:29 PM   #14
69SafariDude
1969 23' Safari
Thanks Lee! (Silverleeper). I just pulled my furnace and swapped blower assemblies using the spare furnace you gave me (had to drill a couple new holes, solder sail switch connections but otherwise piece of cake). The furnace now works great, no noise, puts out the heat. Gave me chance to inspect the heat exchanger too, which was miraculously still fine. I think this airstream sat unused for lots of years, maybe that helped. Thanks again Silverleeper!
Tekonsha P3 giving me 'Brake output shorted' message ronstory Brakes & Brake Controllers 11 05-06-2015 06:30 AM
Generator giving no power output? 911rs Generators & Solar Power 4 09-11-2010 10:20 AM
Christmas Giving using Gift Cards safari57 Off Topic Forum 7 11-23-2008 10:46 AM
Alternator giving me fits!! Jules823 Mechanics Corner - Engines, Transmission & More... 8 08-06-2008 04:25 PM
Do I need a new furnace? Chuck Furnaces, Heaters, Fireplaces & Air Conditioning 37 08-17-2005 05:56 PM
