Old 01-06-2008, 10:41 AM   #1
St Louis , Missouri
Gas valve shut off help
I have a 1972 Safari with no manual. On the heater and refridgerator is the gas off if the value stem is parallel, runing the same direction as the line, or perpendicular, 90 degree angle from the line?
slimitch is offline   Reply With Quote
Old 01-06-2008, 11:00 AM   #2
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
Generally, the line on the valve needs to be parallel to the gas line for it to be open.
Old 01-06-2008, 02:28 PM   #3
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
My 75 TW has gas valves for the heater, water heater and stove (inside the stove). All of them work the way Terry described.
Richard
Old 01-06-2008, 03:04 PM   #4
1972 25' Tradewind
Madison , Wisconsin
When my gas valves are 90' from the line the valve is off.
Smokin Camel is offline   Reply With Quote
Black water shut off valve? '73 Sovereign Al Falcon Waste Systems, Tanks & Totes 10 05-14-2007 04:28 AM
What's this shut-off valve-Argosy MH 28' nohillgrish Plumbing - Systems & Fixtures 4 09-19-2006 04:02 AM
Knob won't shut off gas sequoiacoast LP Gas, Piping, Tanks & Regulators 26 09-09-2006 10:46 AM
Gas shut off valves Sneakinup Water Heaters, Filters & Pumps 1 02-04-2004 10:19 AM
Shut off valve, 1992 30' Motorhome dwc Mechanics Corner - Engines, Transmission & More... 0 07-01-2002 04:50 AM
