Old 05-01-2016, 07:27 PM   #1
trekerboy's Avatar
1979 31' Excella 500
Charlevoix , Michigan
Gas + Spark = ... No Heat?
Problem: Furnace ignitor sparks, propane in the chamber, but no resulting flame (i.e. no ignition).
Question: Do I have a bad ignitor?
Full Story
We were about to set out on our 1st camping trip of the year and the night before as I was testing all the systems I noticed that the furnace wasn't igniting... The furnace is brand new, never used (this trip would have been the 1st time). It's a Suburban NT-20SQ.
Long story short I ended up taking the whole thing apart at 2am convinced that there was just some secret valve that was in the "off" position that I had to turn on to make the thing come alive. No such luck. Put it all back together and my wife called in reinforcements (man do I love her) to help me at 8am the next morning.
Next morning, we pull the furnace out again, take it all apart and confirm the following:
  1. Propane is reaching the furnace
  2. Propane is passing through the furnace's gas valve with adequate pressure into the chamber
  3. The ignitor is sparking
Despite having the essential components needed for ignition (propane and a spark) the furnace just wouldn't light. It would just go through it's cycle 3 times (open gas valve, spark igniter for 7 seconds, detect no flame, shut gas value) then stop trying (fans stays on to vent propane from chamber).
The only thing that I can guess is that perhaps the spark just isn't big enough... looking at the igniter, the spark is just barely visible. Teeny Tiny.
Before I go and order a replacement part, I wanted to get some advice for anyone else who has experience with these furnaces.
trekerboy is offline   Reply With Quote
Old 05-02-2016, 09:05 PM   #2
trekerboy's Avatar
Possibly a mal-adjusted electrode
I did a bit of research and I think the problem is that the two arms of the electrode came from the factory too close together (producing too small of a spark to ignite the propane).
I found a service manual for similar suburban furnaces to my NT20-SQ and there's a section on adjusting the electrode:
Name:	Suburban Furnace Electrode.jpg
When I inspected my electrode, the arms were 1/32 of an inch of less apart. According this service manual they should only be about 1/8 of an inch apart.
I am going to adjust the electrode arm width and see if the furnace will ignite. I'll report back my findings here.
Old 08-13-2016, 08:00 PM   #3
trekerboy's Avatar
Attachment 261773
It worked Fixed.
No Spark on Dometic Fridge 2510 to start the gas Rocker66 General Appliance Topics 3 03-10-2015 12:36 PM
Spark Plug Wire-Heat Boot 345bill Classic Motorhomes 7 05-10-2012 06:59 PM
Atwood water heater -- light on, no gas or spark dre00 Water Heaters, Filters & Pumps 4 02-27-2009 09:51 AM
1975 Argosy MH 454 proper spark plug gap? cejohnsonjr Mechanics Corner - Engines, Transmission & More... 2 04-21-2006 10:17 PM
Burning Spark Plug Wires geodude1958 Mechanics Corner - Engines, Transmission & More... 10 07-10-2005 07:58 PM
