Old 03-23-2010, 10:26 AM   #1
2011 28' Flying Cloud
chanhassen , Minnesota
Gas Smell - Suburban in '76 Globetrotter
Greetings:
Last year I removed my Suburban furnace to clean - it was making a noise and I removed a Wasps nest from the "hamster" wheel. It's quiet and works great but unless I turn off the outside gas feed, there is a slight leak. I removed the threaded pipe that goes into the unit and applied some pipe dope. Still the smell is there.
If anyone has experience in troubleshooting, I'm very eager to know. I know I can buy a new one but this one really does work quite well.
Thanks much,
Ken Tuvman
kentuvman is offline   Reply With Quote
Old 03-26-2010, 07:11 PM   #2
mimiandrews's Avatar
1966 22' Safari
Weatherford , Texas
Use soapy water--homemade or the store-bought stuff--to find gas leaks. A spray bottle is a convenient applicator.
Spray the gas lines, valves, etc. liberally, and then watch closely. A leak will make a bubble.
For your safety, keep looking until you find and fix the leak.
Old 03-26-2010, 11:13 PM   #3
Maniacal Engineer
barts's Avatar
Menlo Park , California
Check out this thread....
http://www.airforums.com/forums/f427...call-2889.html
- Bart
Bart Smaalders
Menlo Park, CA
http://tinpickle.blogspot.com
http://smaalders.net/barts
barts is offline   Reply With Quote
Sewer Gas Smell davespann Waste Systems, Tanks & Totes 18 07-24-2016 08:57 PM
Fleixble gas connectors on Suburban furance? Lothlorian Furnaces, Heaters, Fireplaces & Air Conditioning 6 11-20-2009 07:36 AM
Gas smell in oven Chip Arnold Stoves, Ovens & Microwaves 2 03-21-2009 05:44 PM
Need pictures of gas line for Magic Chief oven gas connection dghaas General Repair Forum 1 01-30-2009 09:04 PM
LP Gas smell when furnace first kicked on Impala SS Guy Furnaces, Heaters, Fireplaces & Air Conditioning 3 09-30-2003 12:08 PM
