Old 02-09-2008, 09:03 AM   #1
DPeakMD's Avatar
1975 23' Safari
1978 31' Excella 500
Franklin , Indiana
Send a message via Yahoo to DPeakMD
Post FYI: Suburban NT-24SP out of production
According to Suburban the smallest of their "NT" line-up is no longer being made.
It was the closest match BTU and size-wise for the NT-22A like my 75 Safari. They recommend 1,000 BTU per foot of trailer length. Their representative recommended going up to the NT-30SP which is identically sized and only a few dollars more.
If you're replacing with the NT style furnace and want to keep the a bottom vent format, Suburban part# 520009 is a bottom vent adapter and you'll need 4 round covers for the side vents which are part# 050733. Both will run you about $20.
I found a source for the NT-30 on eBay Express for $399, much better than $600 elsewhere. I'll post more info about this vendor if everything goes smoothly. Right now I'm keeping my fingers crossed.
Dallas Peak, MD 'That 70's Guy!'
VAC 1VP President
WBCCI/VAC #8481
AIR #9
W9CDC
DPeakMD is offline   Reply With Quote
Old 03-05-2008, 04:11 PM   #2
olddog299's Avatar
1990 25' Excella
Glenburn , Maine
What are your thoughts and impressions a month later? Did the transaction work out as expected? How bad has the conversion been? Inquiring minds, etc.
olddog299 is offline   Reply With Quote
Old 03-05-2008, 04:30 PM   #3
DPeakMD's Avatar
1975 23' Safari
Franklin , Indiana
The transaction was not without a 'hitch' (pardon the pun!). I waited about a week for it to arrive and no joy. Then I started trying to call and couldn't get through. Email address didn't work. Finally I got through and they had essentially misplaced my order. Thought they had shipped but hadn't. Then I got it a day later. All was good. It came in original packaging just like it left the factory. Not damaged.
I went out to do the install and was thwarted by the first (seemingly easy!) step. You have to take the galley's bottom tambor door track off. I spent about 30 minutes looking up down and sideways, but I couldn't figure out how it's attached!!! Oh well. It's going to wait till I have more time.
VAC 1VP President
WBCCI/VAC #8481
AIR #9
W9CDC
Old 11-15-2008, 11:19 PM   #4
Mini Rivet
bmklawt's Avatar
1975 25' Tradewind
Holland , Michigan
DPeakMD, did you ever get this installed, how did it go?
Bruce,
Parts needed: Fan for roof vent or whole vent fan assembly, vented catalytic heater.
My blog for the 1975 Tradewind restoration, Has not been updated in a while but I am still working on it.
bmklawt is offline   Reply With Quote
FYI Tambour Parts Aerowood Cabinets, Counter Tops & Furnishings 8 03-13-2011 01:03 PM
Fyi Rv Expo Silver Threads Off Topic Forum 1 03-06-2007 06:45 PM
1968/69 A/c Fyi Igor68 Furnaces, Heaters, Fireplaces & Air Conditioning 0 09-16-2004 12:00 AM
FYI ...and info appreciated Roze Our Community 3 07-11-2003 03:50 PM
