I tested the furnace about a month ago, and it worked perfectly.
Now, fans start normally, burner lights normally, burns for about 10 sec, then shuts off. On shore power, fresh lp tanks, all else working normally. I suspect that something like a safety system is shutting off the main gas valve.
There is a proof of flame probe that is placed so it should feel the flame and signal the gas valve that there is a flame. That probe may have been moved out of the flame, not likely, or it may have failed.
__________________ WBCCI 12156 AIR 3144 WACHUNG TAC NJ6 2004 Excursion 4x4 1991 34 ft. Excella +220,000 miles, new laminated flooring, new upholstery, new 3200 lbs axles
With the age of your unit, it could be the board. Try cleaning all the connections. They are not cheap. I would inspect the condition of the combustion chamber before I replaced the board.
2012 16' Sport
2015 19' Flying Cloud
Seattle
Drftboat
I was having the same issue a while back.... Everything worked but the heater. It turned out that there was a plumbing leak that dripped water onto the heater's circuit board.
