Old 02-15-2009, 07:23 AM   #1
hurley , New York
furnace wont start
I have an Atwood 7900 series 12 volt furnace. I ran out of propane and now the fan blows for 12 seconds, tries to fire for 6 seconds. It does this three times than the fan just blows cold indefinitely. I have done this several times to no avail. Every thing else gas driven works fine. Please help. Its very cold in the north east. Thanks.
matthew NYC is offline   Reply With Quote
Old 02-15-2009, 08:49 AM   #2
1997 34' Limited
Charlottetown , Canada
no mechanic
I'm no mechanic, however, mine did the same thing and we had to change the circuit board in the furnace. Ours would try to start but would not ignite. At first we thought it was the regulator but that did not work, we had to change the circuit board.
WBCCI9898 is offline   Reply With Quote
Old 02-15-2009, 10:18 AM   #3
eubank's Avatar
1967 30' Sovereign
1999 31' Land Yacht
Bosque Farms , New Mexico
Sounds an awful lot like your running out of propane also caused the propane lines to run out "dry," so to speak.
On our rig, we generally have to get all other appliances (manual strike) to work before the fridge and heater will refire (both auto-strike). But I suspect it kind of depends on how your rig is piped.
But you're sure that there's no cut-off valve to the heater (and fridge) that's turned off, right?
Lynn
WBCCI 21043
eubank is online now   Reply With Quote
Old 02-15-2009, 11:06 AM   #4
Full Timers/Diesel power.
Mike Leary's Avatar
Cactus Hug , Arizona
Images: 11
I'd be looking at the ignitor board, replace it with a "Dinosaur" board. The furnace will
have to come out, so have them check the entire operation at the same time.
Dinosaur Electronics Home. High quality circuit boards for RV appliances.
"A settled wisdom, plus the itch to be elsewhere"
Mike Leary is offline   Reply With Quote
Old 02-15-2009, 01:30 PM   #5
ScottW's Avatar
Hernando , Mississippi
Matthew, I'm sorry but this is too good to pass up...
After you ran out of propane, did you refill the tank or is it still empty?
Seriously, try lighting the stove and let it burn for a minute or two.
Rgds,
Scott
Air 16426
Fully retired now!
Remember:
Never start anything before noon and always plan on being finished by 5.
I will never HAVE to be anywhere ever again!
ScottW is offline   Reply With Quote
Old 02-15-2009, 05:11 PM   #6
hurley , New York
Full tank. I tried it about five times and it finally caught. It has been working well for three hours now. Perhaps only a little air stuck in the lines takes time to purge, or possibly a small piece of dirt was lodged in from the tank and was pushed thru. Either way its working and I thank you all for suggestions and will use them if I have it happens again
Furnace Won't Fire/ Start jnerges Furnaces, Heaters, Fireplaces & Air Conditioning 47 03-02-2014 05:59 PM
Suburban furnace where to start? Pacerized Furnaces, Heaters, Fireplaces & Air Conditioning 37 09-12-2009 12:36 PM
You guys wont believe this... Mrcrowley Nu-Tone Appliances & Central Vac System 7 08-18-2008 01:08 PM
Brake light wont work; where to start. Swat Brakes & Brake Controllers 2 07-11-2007 08:09 PM
Oh no it wont move!! Angel73 Fresh Water Systems 9 03-17-2007 09:56 AM
