Old 11-18-2015, 03:49 AM   #1
Full Time Adventurer
BoldAdventure's Avatar
2007 27' International CCD FB
Nomadic , USA
Furnace won't start
At some point in the night my automatic tank switchover stopped working. And we were very cold. Furnace wouldn't come on, so went outside and discovered one propane tank empty and it didn't switch over. Switched to the full tank, and checked the valve to make sure it was open. Fridge is lighting and I have propane at the stove too.
After some searching, I checked the back of the furnace. Had a red blinking light, so I hit the reset button.
But inside the furnace still will not come on. Have turned the furnace off/on on the thermostat multiple times.
I have read some other threads about jumping the t-state, but mine is just a rj cord to a circuit board, nothing to jump.
I need to get this solved ASAP with little ones and cold temperatures.
Family of 5 exploring the USA with a Ram Power Wagon & Airstream in tow.
OUR BLOG | INSTAGRAM
BoldAdventure is offline   Reply With Quote
Old 11-18-2015, 04:38 AM   #2
SteveSueMac's Avatar
2012 27' Flying Cloud
W , New England
Don't know the answer but do you have an a/c with heat pump? That can at least provide some heat while waiting for grimace answer.
SteveSueMac is online now   Reply With Quote
Old 11-18-2015, 07:29 AM   #3
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
Does the water heater fire up. You may have to continue to light it until all of the air is out of the lines.
Old 11-18-2015, 07:33 AM   #4
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
You may need to purge the lines...
Turn on stove burners.
Turn off DC power to see if it "resets" the board.
Break out the "emergency blankets"!!! Wrap blankets around family like teepee to conserve heat.
Peace and Blessings..
Channing
WBCCI# 30676
Old 11-18-2015, 07:34 AM   #5
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
What model do you have? We can look up trouble shooting for you
Channing
WBCCI# 30676
Old 11-18-2015, 07:42 AM   #6
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Here is the link if you want to diagnose.
Service Documents and Manuals
Channing
WBCCI# 30676
Old 11-18-2015, 08:28 AM   #7
tjdonahoe's Avatar
2013 31' Classic
billings , Montana
You could move to a warmer climate...
Old 11-18-2015, 08:36 AM   #8
Livingston , Texas
Turn the furnace off, turn the thermostat all the way down, remove the fuse for the furnace. That should reset any faults. Replace the fuse and Then restart the furnace.
pattydoug is offline   Reply With Quote
Old 11-18-2015, 08:38 AM   #9
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
From the original problems description I don't see how air would be in the lines.
Old 11-18-2015, 09:14 AM   #10
Nomadic , USA
Great ideas, I went out this morning, and it was flashing the red blinking light again. Did the reset again, it thought about it, then went back to red flashing light. So, might be air in the lines still that I need to purge.
We already had breakfast this morning and used the burners and the hot water turns on, can hear it light up.
I'll try to find the model and do some of the suggestions here this afternoon and get back to the thread if it persists.
I plan too, but it's actually warm in the days. Going up to 70 today. Also, I work so I can't just up and move till the weekend.
Old 11-18-2015, 10:21 AM   #11
2016 30' Classic
Erie , Colorado
Here's a couple of docs that might help. One is the the blinking light pattern if there is one. The other is general trouble shooting.
Name:	Screen Shot 2015-11-18 at 10.19.34 AM.png
Atwood Furnace Troubleshooting.pdf
Gary
2015 Classic
2015 GMC Sierra 2500HD Duramax
ProPride
NVPN
ghaynes755 is offline   Reply With Quote
Old 11-18-2015, 10:29 AM   #12
1987 Avion 34W owner
PaulnGina's Avatar
Good Ol' , USA
Good luck with it, Bold. I bet it's air in the line.
Whats good for me may not be good for the weak minded.
1987 Avion 34W
1995 Ford F250 7.3L PowerStroke
PaulnGina is offline   Reply With Quote
Old 11-18-2015, 12:32 PM   #13
Nomadic , USA
Attachment 252444
Attachment 252445
This is great, I have Model 8525-IV DCLO and it appears I have 1 flash with a 3 second pass, so limit/airflow problems.
There is a slight hum coming from the unit.
Old 11-18-2015, 12:48 PM   #14
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Is there air moving? Did an Umpa-lumpa's thumpa get stuck in the return air vent???
Channing
WBCCI# 30676
Burner and Blower Won't Start For Furnace heyhello Furnaces, Heaters, Fireplaces & Air Conditioning 14 05-31-2015 04:59 PM
Furnace Won't Fire/ Start jnerges Furnaces, Heaters, Fireplaces & Air Conditioning 47 03-02-2014 05:59 PM
My RV will start using the Aux Start but not with the chassis battery mcm9970 Land Yacht/Legacy Motorhomes 7 05-19-2013 07:47 PM
Furnace Won't Start perryg114 Furnaces, Heaters, Fireplaces & Air Conditioning 27 10-14-2012 12:40 PM
Hydro Flame furnace blower quit working won't start nsteel Furnaces, Heaters, Fireplaces & Air Conditioning 3 01-04-2010 03:27 PM
